Thread: Wynns Diesel EGR3 Air Intake & EGR System Cleaner
    Regular Member Gazz's Avatar
    May 2011
    N.Ireland
    Default Wynns Diesel EGR3 Air Intake & EGR System Cleaner
    Any one used this? Was it easy?
    Aug 2012
    South Wales
    Can't comment on the wynns mate but the 10k boost cleaner is good s**t there a how to on here but do try and do it where the smoke won't bother people cause it does through out a lot done mine and easy to do mate
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Used it a couple of times fairly straight forward just need to disconect the intake hose from the maf and empty the canister into the intake with the engine running at around 2k rpm .
    If the engine is well clogged up then its not really worth doing as you will only be partually cleaning the egr and of course there is areas where the cleaner cannot get like in around the cam on the Dti egr,s
    BG 244 will probably do a better job for cleaning egr,s and manifolds but is usually twice the price .
    Aug 2012
    South Wales
    Thought bg244 was a fuel treatment not a air intake treatment
    May 2011
    N.Ireland
    Got the 2.2 DTi, Heard a few people have done both the EGR3 aerosol (2 cans if its clogged) and a DP3 or an HP3 liquid so wondering if its worth hit.. My DTi has just hit 83k and the Turbo got replaced about 10k ago so tempted just to do it and see!
    Engine : 2.0DTi
    Mileage : 73350
    Link for BG244 Diesel engine injector cleaner
    http://www.ebay.co.uk/itm/BG244-BG-2...item2ec1e0a5e2
    May 2011
    N.Ireland
    cheers buddy may try it with the Spray and give it a good clear out, might also replace the boost sensor on the Turbo as it was never done!
    Regular Member Mission1979's Avatar
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    Tried it after cleaning throttle body, egr and boost valve individually with carb cleaner the same week. Expected clouds of black smoke, but nothing of the sort, engine shook a lot as I sprayed into the intake. No real gain. Will try something different in a year of so.
    May 2011
    N.Ireland
    So i bought EGR Aerosol i assume being a complete nub, i disconnect the Airintake at the nice shinny red paintshop arrow and spray the Aerosol in there at intervals?
    Aug 2012
    South Wales
    Ye that's it mate
  1. Wynns EGR3
    By MattW in forum Engine & Drivetrain
    Last Post: 7th March 2011, 09:41
  2. Wynns Diesel Fuel System Cleaner
    By congaman in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2010, 16:50
  3. Wynns EGR3 any different from Carb Cleaner?
    By richardn in forum Engine & Drivetrain
    Last Post: 4th June 2010, 19:29
  4. wynns EGR3
    By den2712 in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2010, 13:19
  5. Wynns EGR3 spray - wow!
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2009, 18:29
diesel egr 3 spray cleaner vectra c
wynns egr3 diesel
