Thread: engine change help
    May 2012
    tyne and wear
    confused engine change help
    need some help lads am going to change engines on my vectra cdti 150 sri 06 hatchback. this is where i need some advice the engine thats in car has no DPF (a think) is it only estate that have DPF... will this be an issue on putting another engine in...the engine am thinking of putting in came off an alfa romeo and a dont know if that has a DPF or not cheers if any one can help me with this or any other issues i might have changing engines
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Dpf is a part of exhaust and ecu software as long as ur original stay where they are I don't see problem with it
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    What Alfa is it ?
    wirral
    57 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    As above aslong as your keeping your electrical hardware an just changing block it won't make a didifference but I believe autos also had DPF but I could be wrong
    wirral
    57 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Isn't the Alfa set up slightly different. I mean bare block is same. But bell housing etc is different an injectors etc different too?
    May 2012
    tyne and wear
    alfa 159 its just a bare engine
  1. How often do you change your engine oil?
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2011, 13:32
  2. change my engine!!!
    By bedo13 in forum Tuning
    Last Post: 28th July 2010, 23:50
  3. had engine change
    By Nojustice in forum Engine & Drivetrain
    Last Post: 13th January 2010, 14:20
  4. engine change
    By yadziyad in forum Diesel Engine related
    Last Post: 22nd May 2009, 20:38
  5. Engine change
    By stevedee in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2008, 17:28
