Thread: 53plate vectra c estate indicator problems
    Jan 2012
    High Wycombe
    Default 53plate vectra c estate indicator problems
    Hi,
    wondering if anyone can help, my rear passenger side indicator is permantly on even if car is off and locked causing the battery to drain. It doesn't flash with the indicators on, just stay lit and also tried with hazards switch and all others work fine apart from this one which again is permantly on.
    checked ALL bulbs and they are fine, tried taking out relays on rec module but no of them seem to effect the indicators working.
    anyone have any ideas as had to unplug bulb for now so don't drain battery!
    Full Member witty's Avatar
    Jul 2011
    HALESOWEN
    Vehicle : VECTRA C.
    Trim : ELITE
    Engine : 2.0 DTI.
    Mileage : 106600
    This usually happens to mine when side light bulb goes. Just check all the connectors to make sure they are all secure...
    Jan 2012
    High Wycombe
    Hi, thanks for the reply but there are no bulbs out, and i cant beleive vauxhal would make a car that would drain the battery by having the indicator bulb permantly on even when car is locked due to a bulb not working in the tail light? So any other suggestions or would the rec unit be knackered for no apparent reason?
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    try swapping all your bulbs in the RHS lamp with the LHS lamp. it will give you an idea whether its the bulbs or not.
    Jan 2012
    High Wycombe
    ok will try that in the morning.
    Jan 2012
    High Wycombe
    Well found the problem, Decided to open up the REC module and found this! How is this even possible! photo(1).jpg
  1. Wiper problems 56 V estate
    By scot baker in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2012, 05:58
  2. indicator problems
    By hotterpus in forum Vectra C / Signum Troubleshooting
    Last Post: 12th June 2012, 16:15
  3. 100k service on 53plate vectra c 2.2dti sri
    By sjs in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 15:32
  4. indicator problems
    By sbd16v in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd May 2009, 23:24
  5. Vectra Elegance 2.2i 53plate T&T £2500 ono
    By vvc Baz in forum Cars for sale
    Last Post: 22nd November 2008, 14:59
