Results 1 to 10 of 27
Thread: Blowers not working on any speed
    Oct 2012
    Default Blowers not working on any speed
    I posted last night regarding thermostat issue.
    Just went to local factors to get the Stat, and noticed blowers seem to have packed up! I hear clicking of relays but fan doesn't work on any speed.
    Anybody experienced this or offer any help?
    Regular Member Vectra Adz's Avatar
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Heater resistor are common on these???
    Oct 2012
    Would that stop all speeds?
    Nov 2010
    East Midlands
    Trim : design
    If its packed up completely it will knock all settings out - if the thermal fuse has gone on the resistor pack you should still get no 4 setting - have you checked all your fuses - there in the passenger comparment fuse box, no2. - 7.5 amp and no 23 which is a 30amp fuse - worth a check before you do any thing
    Oct 2012
    Thanks, will check the fuses a bit later
    Can someone post a link to this resistor I'd need if not?
    Nov 2010
    East Midlands
    Trim : design
    Vauxhall part no. 9180020 Loads on Ebay - some expensive ones and these - http://www.ebay.co.uk/itm/OPEL-VECTR...a38090c&_uhb=1
    Here's the How2 to replace/repair it http://www.vectra-c.com/forum/showth...=1#post1495923
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    Quote Originally Posted by noonaldinho View Post
    you should get number 4 working
    resistor pack works 1 2 3 heater settings
    Oct 2012
    Quote Originally Posted by vectra ste View Post
    No none work, could suggest fuse then?
    Oct 2012
    just checked the 2 fuses in passenger side box the big 40a and the 7.5 both ok.
    I then removed the resistor, measured across it with my multimeter and got over range, would this suggest the resistor?
    Oct 2012
    Anyone?
  1. Heaters/Blowers Only Working on No. 5
    By Madison5 in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2013, 00:47
  2. Blowers not working on number 1
    By tubby in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2012, 12:19
  3. Blowers not working on position 4.
    By Slammedorion in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2012, 18:01
  4. Blowers not working
    By DJM in forum Electrical & ICE (including SatNav)
    Last Post: 3rd February 2012, 19:06
  5. blowers only working on speed 4
    By cooki in forum Bodywork & Interior
    Last Post: 5th December 2009, 21:30
