Results 1 to 10 of 15
Thread: 2.2 dti fuel filter change
    Jul 2011
    UK
    Year : 06
    Default 2.2 dti fuel filter change
    Anyone point me in the right direction of a link or how to change it over thanks in advance.
    Sent from my Nokia 3310
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    not sure where it is on your car but mine is underneith the car on the rear left passenger side. has 2 clips. should just clip of.
    Jul 2011
    UK
    Year : 06
    Will there be fuel everywhere do I have to disconnect hoses etc its not my car lol sorry should of said
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Changed one on a vectra 2months ago. Check towards the rear (before the rear tyre) of the car on the driver's side. Just close to where the jack goes to lift up the car. You will have to depress the clips on either sides of the filter with a screwdriver or something else you can get away with. The clips to depress are 180degrees from each other.
    If you don't want to lose too much fuel from the hose, unclip old filter on one side and attach new filter, then unclip from the other side and clip the new one in as well. Be ready to get fuel spill from the filter itself though. HTH
    Sep 2010
    north east uk
    You sure we are talking DTI here? Mine is engine compartment next to the radiator header tank.
    Regular Member krazylegz's Avatar
    South Shields
    2.2dti's aren't under the car, that is on petrol models. On dtis it's the black think to left of the header tank with 2 pipes and a wiring connector for the fuel heater
    Sent from my iPhone using my fingers n thumbs
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Still trying to get payment in kind i see!!! Any luck so far?
    The fuel filter is at the back of the engine on the bulkhead next to the radiator expansion tank.
    Make sure the engine has been shut down for a bit to let the pressure subside.
    There is a bolt on top you undo and the filter canopy lifts off. I didnt undo any pipes when i did mine.
    Change filter and refil the chamber with fuel, and then replace the canapy.
    It may start first time but will soon conk out, need to try and keep the revs up the second it starts.
    If it shuts down , then it takes a while to restart. Always makes me nervous at this point.
    But it eventually does.
    Good luck.
    Jul 2011
    UK
    Year : 06
    Cheers lads thanks as for payment that will be next week but will be notes and not what u think pmsl.
    Fitted the intercooleer hose today they took the car to 2 garages looked under bonnet didn't have a clue would have to plug it into a comp I look under and find what's wrong lol
    Sep 2010
    north east uk
    Also a good idea to drain the filter housing before you put the new filter in & fill it with fuel, just in case there has been any water ingress settling at the botom of the canister. Did mine last week & there is just enough room to hold an old cup or similar to catch the dregs.
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by mick.n
    Is there a drain hole or summit on it lol
  1. Fuel filter change?
    By parky1 in forum Engine & Drivetrain
    Last Post: 13th August 2011, 22:24
  2. fuel filter change vec c 2.0t
    By johnturbo in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 19:36
  3. Fuel filter change
    By juggernaut in forum Engine & Drivetrain
    Last Post: 5th March 2009, 16:18
  4. How to change fuel filter?
    Last Post: 31st January 2009, 14:48
  5. 1.9 Fuel filter change
    By Keith Jones in forum Engine & Drivetrain
    Last Post: 11th October 2008, 21:11
opel vectra c 2.2 dti fuel filter
How to chang fuel filter signum 2.2 diesel
change fuel filter vectra 2.2 dti
zafira dti fuel filter cap
vectra c 2.2 fuel filter change
opel vectra c 2.2 dti fuel heater
how many fuel filters vectra
where is fuel filter on vectra
vectra c fuel filter change www.vectra-c.com
How can change opel signum s fuhl filiter vidio
vectra c 2.2 dti fuel filter change
how to change a fuel filter on a vectra c 2.2
opel signum 2.2 dti fuel filter change
vauxhall frontera 2.2 dti fuel filter location
changing vauxhall vectra fuel filter
frontera 2.2 dti fuel filter removal
vectra 2.2 dti where is fuel filter
opel signum 2.2 fuel filter replace
2.2diesel frontera fuel filters
