Results 1 to 10 of 13
Thread: Timing Tensioner, head size
    Aug 2011
    Bristol
    Default Timing Tensioner, head size
    Hi.
    As title, trying to take the tensioner out from back of engine.
    Didn't realise how big the head is. Anyone know what size it is cause I don't have anything that big?
    It's bigger than my adjustable!!!
    Any tricks to getting this out?
    South east
    Perhaps give is a clue as to which engine you're referring to, or is guessing part of the fun?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Got to be a 2.2 or 2.0 with the position of the tensioner.
    Edit, its a Z22YH
    Sent from my Nexus 7 using Forum Runner
    Aug 2011
    Bristol
    Sorry, keep forgetting there are differant models.
    2.2 Z22YH
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    are you doing a timing chain replacement or just the tensioner up grade??
    Aug 2011
    Bristol
    Timing chain replacement due to tensioner going.
    Taking head off to be checked for bent valves as suspect jump on the chain. Replacing water pump, timing and balance chain (kit) and checking pistons/bottom end for damage due to the smallest piece breaking off the guide rail under the cam cover.
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 85000
    Ouch!! make sure the replacement kit has the tensioner with the domed top, search on here there is a picture,, HTH
    Aug 2011
    Bristol
    The company I may be getting it from are adament it is the second generation. They told me it is still oil feed but also has a spring in it.
    Is that correct or does that still sound like the crap one. Might have to wait until I get it and see. Will send back if I think it is the same.
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 85000
    the ones that is used is from a Z20NET engine timing kit on the Z22YH, this link to the 2.2 se web site should help
    http://www.z22se.co.uk/forum/threads...engines.15533/
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    The 2.2 site sell the correct kit in there shop. Gen GM as well.
  1. timing belt tensioner question
    By wildchild in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2013, 15:25
  2. Head Gaskets and Timing Belt must be made of gold
    By Mawbs in forum Y & Z30DT Specific
    Last Post: 16th June 2012, 20:21
  3. Really struggling with timing belt tensioner
    By golfpro in forum Engine & Drivetrain
    Last Post: 6th June 2012, 00:18
  4. Timing Chain & Head Gasket Issues
    By rocket999 in forum Engine & Drivetrain
    Last Post: 14th December 2010, 19:07
  5. Bolt head size on front brakes
    By NPS in forum Suspension, Wheels & Brakes
    Last Post: 14th January 2009, 11:07
