Thread: ashtray removal
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default ashtray removal
    Wanting the live feed from the cig lighter for a voltmeter. How do i get to the wiring, remove the cover etc
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Preface btw
    Regular Member farley2708's Avatar
    antrim n.ireland
    ashtray just lifts out by the lid,then you lift/click out the inside,take out the plastic surround around the gear-stick gaiter aswell,lift up the gaiter to the bottom of the gear knob that will leave with plenty of room to get your hand in to unplug the power going to the cig lighter,just pull down towards the floor
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    thank you
    antrim n.ireland
    when your in there you might find a spare connector for the light to the ashtray(little square window thingy on the left of inner ashtray),i fitted a 5mm LED to mine,just lights it up a wee bit
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    how about the cubby hole above it, easy to get out, thats where i want the meter
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by andy_richmond
    When ya ashtray is out pull the cuppy from the button it is easier to remove the heater panel 1st grab hold of the left and right knobs and generally pull and it will clip out
    Sent from my Nokia 3310
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    cheers
  1. Front Ashtray Removal On Vectra 'C'
    By vectracman in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2010, 14:59
  2. Ashtray
    By Stephen S in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2009, 18:49
  3. What's under the Ashtray
    By squigles in forum Vectra C / Signum Troubleshooting
    Last Post: 13th January 2009, 02:32
  4. Ashtray??????
    By stubopvectra in forum Styling
    Last Post: 2nd April 2008, 11:47
  5. Under ashtray
    By afterburner in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2006, 22:42
signum ashtray removal
remove ashtray vectra c
