Thread: Double din flush fitting?
    Regular Member krazylegz's Avatar
    South Shields
    Default Double din flush fitting?
    Has anyone managed to get their double fitted flush?
    I have the connects2 fitting kit and the black fascia surround sticks out quite a lot conpaired to the grey adapter?
    Sent from my iPhone using my fingers n thumbs
    Ex-Staff Full Member Spelly's Avatar
    Derbyshire
    Mine does now. I had the same problem with mine, facia & cage fits flush but black surround round the edge sits proud about 5mm. I used a bench / belt sander on the back of it until it sat flush, then held it in place with a small slither of number plate tape in each corner, its a bit of a rough method to get it to fit but looks fine once in place
    Jul 2011
    UK
    Year : 06
    I have I used a dremel and cut so much off and stuck on in to the dash
    Sent from my Nokia 3310
    South Shields
    Thanks lads
    Bit of a stupid design they done ain't it, looks like I'll be sanding or cutting it down then
  1. Double din fitting kit
    By stevie16v in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2012, 22:06
  2. Double din fitting kit
    By rob2.0t in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2012, 20:57
  3. Double din fitting help
    By blackveccyC in forum Electrical & ICE (including SatNav)
    Last Post: 17th February 2012, 22:39
  4. Getting Double Din to sit flush?
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 18th December 2011, 15:52
flush fit double din
