Thread: Exhaust Gas Recirculation Circuit Open
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    Default Exhaust Gas Recirculation Circuit Open
    P0400-04
    I know this is egr valve it came up when I did inlet manifold
    the software that cannot be mentioned says
    trouble is the plug wont clip on tight could that be the reason im getting this
    p400 is the egr code does the -04 mean anything extra?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    There should be a clip that stops the plug coming out, either this is missing on yours or is broke.
    Jun 2012
    lancashire
    been out messing with it got it to clip back up it stays on if I pull on it now it just wasnt pushing up correctly but still have the fault
    Jun 2009
    Middlesex
    Having a EGR Valve problem.I have a 2.2 Direct.Went into VX last week.Tech 2 PO403 EGR CIRCUIT MALFUNCTION.
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    try cleaning the contacts in the plug with electrical cleaner it may be somthing as simple as that mate .
    Jun 2012
    lancashire
    Eventually mine fixed its self no idea why I couldn't clear the code but it has done its self
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Sometimes they need to be driven a few miles to clear. Odd, as they usually clear right away when problem the EGR valve is plugged in or cleared of any obstruction.
  1. P1482-04 fan control 2 circuit open
    By mack in forum Engine & Drivetrain
    Last Post: 28th March 2014, 17:54
  2. Replies: 5
    Last Post: 3rd January 2013, 21:56
  3. All glowplugs open circuit ?
    By trimble in forum Engine & Drivetrain
    Last Post: 12th April 2012, 16:14
  4. PO409 exhaust gas recirculation "A" circuit
    By billy_wiz in forum Y & Z30DT Specific
    Last Post: 6th February 2012, 09:13
  5. ddm open circuit????????
    By jpbroad1970 in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2012, 23:55
p0400-04 exhaust gas recirculation circuit open 2.2 fuse
egr valve open circuit vectra
egr open circuit vectra c
p0400 04 egr circuit open
p400 fault code vauxhall 2.2 diesel
vectra c where is the fuse for egr
vauxhall zafira fault code p0400-04
1.9 cdti egr open circuit fault
