Results 1 to 10 of 13
Thread: Bigger battery?
    Regular Member toaffer's Avatar
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Engine : 1.8 VVT (Z18XER)
    Mileage : 73K
    Default Bigger battery?
    Awrite Chappies? Quicky for you......My bro has a 1.6 astra H petrol with a smaller battery than the tray, he has been through 3 batts in four years, do you think it would be ok to put a bigger batt in, as i think the small one is not up to the job hence the replacements,say out of a 1.8 or 2 litre?
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    all to do with the amps, not sure if there would be a difference between them?
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Mileage : 73K
    Cheers for the quick response bud, my bro has just got a batt from scrappies so see what happens lol
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    chances are the ones he has had are calcium ones whilst they have big cranking amps ect there really hard to get to charge back up once flattened id suggest putting a little solar panel on the dash and connect it to the battery to trickle charge it when its not running
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Quote Originally Posted by toaffer View Post
    Thats the issue usually... I'd just by a new one, but I always go a few cranking amps higher then the standard when I replace...
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Mileage : 73K
    Well hes just off the blower, got one out of a box of several @ the scrappies for a tenner!, dont know what he came home with but he says all is well....... So far!
    Dec 2011
    Seaham
    You can get higher amperage batteries in the same casings, he may have been getting a lower amperage battery because it was cheap?? YOu may find that although you have bought a physically bigger battery, it will have the same or a lower cranking amperage. Read the labels on the battery carefully.
    Also check the charging system as the alternator may be starting to fail and the battery will die again in the winter as the cold temperatures make it harder to start the car and also you will be running a lot more accessories.
    If you can get someone who has a de-sulphinating charger, ususally one with a small amperage, then a long slow charge witll de-sulphinate the plates.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    i always fit the biggest battery i can fit.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    I put a bigger one on mine. Sure it was 55amp originally, and I put a 70amp one one 2 years ago.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    100 amp on mine... bit of overkill but iv got plenty of 12v on tap if i go camping or anything that uses 12v.
  1. Bigger brakes
    By Fuzzynuts1984 in forum Handling & Braking
    Last Post: 9th March 2013, 21:08
  2. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  3. bigger alloys
    By leeandjude in forum Vectra C / Signum Car Chat
    Last Post: 17th September 2007, 19:34
  4. Bigger calipers???
    By Auto-Brite in forum Handling & Braking
    Last Post: 28th August 2007, 22:27
