Thread: spanner light
    scottish region
    Default spanner light
    keep getting this coming up and car in limp mode but no stored faults as its not the actual engine managment light thats on any ideas
    i have a split intercooler hose could this cause this
    11 Post(s)
    The car/spanner light is the engine electronics light, autobox fault (if fitted), and immobiliser fault light (if flashes and car doesn't start)
    The other light which I think you're saying is the engine managment light (the one that looks like an engine block - also used to have a lightening bolt through it) is actually the emissions fault light.
    What are you using to extract the fault codes with?
    scottish region
    Aa used equipment no stored codes decided to do pedal test and its dpf filter so going for a remap and dpf removal
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try getting codes read with engine running
    scottish region
    Engine was running mate its the dpf getting it removed with a remap also this week
    scottish region
    Turns out it was deffo the dpf so its been removed
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
