Results 1 to 2 of 2
Thread: ABS fault light
    Chelmsford
    Default ABS fault light
    Hi guys,
    Got the ABS light on since I replaced a wheel bearing the other day. Probably my fault as I had to start up with the ABS sensor unplugged to turn the steering.
    Anyone know if it will go out by itself after a few journeys with everything working, or will I need to reset it?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    It should clear itself eventually - or get it cleared via Tech 2 (other devices are available ) - or try disconnecting your battery for half an hour and that may clear the fault - all this depends on the fault not being still present
  1. 2.0 tdi fault light
    By vauxpower in forum Engine & Drivetrain
    Last Post: 22nd January 2011, 17:54
  2. fault light ??????????
    By iam2103 in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 08:46
  3. fault light
    By homerj in forum Engine & Drivetrain
    Last Post: 19th September 2010, 15:56
  4. fault light
    By trev16185 in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2009, 19:56
  5. TC AND ABS LIGHT Serious Fault
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 13th November 2008, 19:49
