Results 1 to 10 of 18
Thread: Spanner light Conundrum
    Jun 2011
    Paisley
    Default Spanner light Conundrum
    Hi Everyone,
    I have a real conundrum regarding the spanner light and engine cutting out. When I switch on the ignition the spanner light is there, then once I start the car it goes out. When I rev the engine or try to drive, the spanner light comes on and 5 seconds later the engine cuts out.
    I do not have access to a code reader. Has anyone experienced this at all and if so could you pass on some advice please? I would be really gratefull.
    Would disconnecting the battery overnight allow the codes to clear? I seem to remember reading that somewhere, although I may be guessing.
    Thanks in advance.
    Lynchy.
    Dec 2011
    Seaham
    You really need to have the codes read, they will re-occur until you get the problem fixed and the car will continue to go into limp mode.
    Jun 2011
    Paisley
    Hi again everyone,
    Had a code reader plugged in and it came up with no fault found. I can be driving ok, then spanner light comes on and engine cuts out. When I go to start it again it turns over but won't start. Then when I try again it starts up no problem. Can do this a couple of times over the space of 5 minutes or so, and then everything will be allright for about a week and then the same thing can happen again. I am at a loss as to what may be causing this and I need a starter for ten....Please!
    Thanks in advance.
    Lynchy.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Are you reading the codes with the spanner light on?
    Jun 2011
    Paisley
    Yes, reading codes both with spanner light on...and when it is off as well. Both readings coming back with no codes found. I am totally confused. Car running okay at the moment, but could do the same thing next time I go out in it. Very frustrating.
    Lynchy.
    Jun 2011
    Paisley
    Anyone got any ideas please?
    Lynchy
    11 Post(s)
    What type of code reader you using?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Need that laptop software rather than a hand held reader
    ---Sent from my iPhone 4 using Forum Runner
    Aug 2009
    spain
    I have the exact same problem.
    Can be driving along fine and then all of a sudden "car and spanner" light comes on and engine cuts out. If i try to start immediately it it just does the same thing. If I leave the car for a while and then try, if light does not come on car drives fine. This happens has been intermittently perhaps once or twice a week for the last couple of months or so.
    Did anyone manage to fix this? Is there a way to have the car display error codes without any special device? (maybe pressing a combination of control panel buttons)
    Car is a 2003 Signum 2.2 DTI Y22DTR which has done 150.000 km.
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Engine : 1.9 cdti 150
    Mileage : 119k
    We used to experience a very similar problem with our old vectra 2.2dti. I found cleaning the boost sensor located at the front of the engine woukd cure the problem. Only takes a few minutes to clean, we did ours once a month to prevent the problem reoccurring. Gotts be worth a try as its so simple to do.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. Conundrum Time...What is my motor worth?
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2007, 17:27
  5. Possible New Job....Conundrum Please help.
    By Brocks in forum General Chat
    Last Post: 12th January 2007, 22:16
