Thread: More problems :-(
    Sep 2012
    Carlisle
    Default More problems :-(
    Another couple of problems i have, since iv owned the car (150 cdti) on the odd occasion the car jolts as if its totally lost power for about half a second, then it does it 4 or 5 times in the space of a minute then dissapears ?!?!? it feels as if iv let go of the accelerator and someones pulling the car back when it happens. very odd and very frustrating as i have no idea and neither does my local garage, can anyone shed any light on this please
    also i have a nasty flat spot at pretty much 2000rpm, its quite a big dead spot as if the car just stops for a fag then gets going again
    sorry all my posts are about problems at the moment but big thanx to all the advise iv had so far its helped me %100 and saved me a bob or 2 :-)
    Dec 2011
    Seaham
    I take iy you have checked the usual culprits and cleaned the EGR, MAF and the DPF isnt blocked?
    Sep 2012
    Carlisle
    Quote Originally Posted by Ben50n View Post
    Again im no expert, im a bit of a novice so still learning, iv just read a thread about EGR, is that by the bonnet slam panel that has to come apart to clean or remove the mesh filter inside?
    Sep 2012
    Carlisle
    MAF im asuming mass air flow, how and where would you clean/unblock this?
    Dec 2011
    Seaham
    I dont have a diesel, so just what I have picked up on here. Exhaust Gas Recirculation valve gets gunked up, you can split it open and clean it with carb cleaner and a toothbrush. There will be numerous posts about it.
    MAF can also be cleaned by carefully squirting carb cleaner onto it. It will be on the side leading from the airfilter and has a plug on it, again plenty of posts on here.
    The diesel guys will give you more advise.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    If ya stuck mate bob it down to me I will sort it for ya
    Sep 2012
    Carlisle
    Really, that would be a huge help, where about are you located and how much would i be looking at. im origionally from Birmingham but i live in the centre of carlisle now
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Usually culprit is the 3rd injector wiring, I am sure paulvectrac will have a look at it for you.
    Regular Member shinyb1's Avatar
    Jul 2011
    wigan
    mine was egr sticking that was causing the hesitation , and the flat spot was my boost pressure sensor - a good clean sorted it out . i do mine every 4 -6 months , very easy to do but dont scrub the boost sensor just spray or soak in carb cleaner . i cleaned the egr valve with a toothbrush and carbcleaner . make sure you split the egr valve and give it a good going over , when you split it you will see the pin coming out the solenoid that should be free and moving and you will see the spring in the egr wich sticks .
    Jul 2011
    UK
    Year : 06
    Am from Carlisle too lol egr clean and boost sensor check vacuum hoses there the main culprits
    Sent from my Nokia 3310
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
