Thread: maybe thermostat
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default maybe thermostat
    when i have the heaters on cold the temp gauge on the motorway sits about 85-90, with heaters on it never gets above 80. thermostat or sounds about right??
    Nov 2010
    luton
    hmm, not an expert but regardless of temp and motorway etc my gauge when warm always sits at 85
    a change to 80 indicates a possible problem but nothing that i would worry about changing the stat at this time
    Dec 2011
    Seaham
    Normally when a thermostat has gone, the car will only warm up when its stationary and as soon as you move off, the temperature gauge falls quite quickly as the car is over cooling.
    The thermostat may be sticking slightly, and can be changed for peace of mind.
    Sep 2012
    Carlisle
    I have no reading on mine from a stand still or moving so im going to change the thermostat and the temp sensor and hope for the best
    Aug 2010
    Leeds
    Quote Originally Posted by Basher1 View Post
    Remember the gauge starts at 70c not zero!
    Mine takes a few miles before it starts to go up and with the chilly weather it may take a little longer should you have the heating on as your pulling it away from the engine.
    On a good run on the motorway when hot it should be around 84c give or take.
    Nov 2010
    luton
    yes, i run a 1.9cdti and it takes around 5 miles or 10 mins depending on weather to get the needle to 85c
    i changed my thermostat last year after it sat at 70 even after a good run on the motorway,
  1. thermostat
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2012, 18:08
  2. Can anyone tell me what a thermostat does?
    By twinxster in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 22:03
  3. Thermostat?
    By killa_uk in forum Engine & Drivetrain
    Last Post: 31st January 2012, 18:35
  4. can it be anything other than the thermostat
    Last Post: 20th January 2011, 22:36
  5. thermostat or thermostat kit?
    By IA76 in forum Engine & Drivetrain
    Last Post: 24th September 2010, 11:33
