Thread: radiator flush
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Default radiator flush
    Hi all how easy is it to remove the radiator from the z20net? pics would be an advantage. wanting to flush the system
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    12 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    why would you want to remove it to flush it?..I undid the drain plug on the radiator and flushed it all through,using a hosepipe, via the water bottle fixed near the bulkhead.
    6 Post(s)
    You should be able to flush it in situ.
    Aug 2011
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Yeah a know but I want to give it a really good clean. Having problems with over heating. It's not the head. Think there might be a blockage somewhere.
    Aug 2010
    Leeds
    Is the thermostat ok & the water pump impelor not broken?
    As said flush in situ make less work.
    6 Post(s)
    Quote Originally Posted by beat275 View Post
    You will see if you've got a blockage by flushing it in situ. If you have, then spend time taking it out. Otherwise it's a waste of time.
  1. Intercooler radiator removal without water radiator
    By Whosane in forum Troubleshooting
    Last Post: 5th December 2012, 15:48
  2. 1.9cdti - 150 Radiator flush
    By roswell in forum Engine & Drivetrain
    Last Post: 5th October 2011, 19:04
  3. Flush or No Flush(2.2Dti)
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2009, 20:35
  4. to flush or not to flush
    By copperdock in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2008, 22:56
  5. Flush fit sub
    By rushy in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2005, 23:05
vectra c radiator flush
z20net radiator removal
