Thread: dpf advice
    scottish region
    Default dpf advice
    ok wanting to start getting rid of this so heres my plans if anyone has any advice
    1.get exhaust place to remove dpf and put in pipe (i know i will have a warning light) october 2012
    2. get it remapped out with more power febuary 2013
    question is will this be ok to drive with the warning light and will it fail its mot in november with a warning light (if yes) can this be done after mot thanks advice appreciated
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    not sure mate as i dont drive a derv and never had one to mot, why not bring you mot forward to october and remove it after the mot?
    Nov 2009
    newcastle
    No need for pipe. Just take off and drill thru or bash the inside. Just don't break any sensors. Car should be ok. I'd reccomend doing all together as with the light on might stop you seeing other warnings on the dash
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Quote Originally Posted by DAVIDD88 View Post
    Im pretty sure that if the eml is on and a fault code is stored relating to the emmissions side of things it will be a fail, personely i would do as geordieric said and just remove insides and put a straight through pipe on the inside that way it looks standard for any future mot's just incase, i have also read that you could crimp over the pressure pipe that goes to the front of the dpf(after removal) to fool the ecu but dont know if it does work 100% of the time
    scottish region
    Car has dpf removed and just to get mapped out with extra power also
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
