Thread: Forced Regeneration
    Default Forced Regeneration
    I took my 1.9cdti 150 in to the garage the other day as when it is ticking over it feels like the car is bouncing and isnt smooth when crawling until you get above 1700 revs.
    It has had a new EGR valuve, (previous owner). The garage said that it might need a regeneration as I only do town runs and a lot of stop start.
    Not sure what this means.
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    get on the motorway and give it a good burst up and down let everything get up to temp and see if it will kick in and do its own regen
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    If I understand this correctly, the DPF catches a lot of the sooty grot that exits the engine and at various points the DPF then does a 'regeneration' where it uses fuel to burn off the accumulated aforementioned grot. If you're doing short journeys then the DPF will clog up, your engine will suffer and you can get on some low-rent BBC consumer programme complaining about how your car doesn't work properly.
    Is there a noticable change when you do this?
    Regular Member mark1976's Avatar
    Barrow on Humber
    Is your car an estate or an auto if it isnt that I dont think it will have a DPF fitted.
    Regards
    It is an estate 07 reg done 71k.
    Regards
  1. regeneration
    By Swedge in forum Engine & Drivetrain
    Last Post: 29th July 2012, 14:48
  2. DPF regeneration
    By Jekyll & Hyde in forum Diesel Engine related
    Last Post: 16th June 2012, 20:07
  3. DPF Manual Regeneration
    By McSqueesh in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2012, 12:54
  4. Dpf Regeneration
    By jb1kenoby in forum Engine & Drivetrain
    Last Post: 17th July 2010, 20:57
  5. Forced Air Induction Kit.
    By Cheeky_B in forum Parts for sale
    Last Post: 24th April 2006, 11:37
opel forum forced of fap regeneration
