Thread: power steering problem
    May 2011
    sunderland
    Default power steering problem
    Morning lads ive got a vectra c cdti 06 plate and the steering is tight it feels like im driving with a flat tyre. Ive topped up the fluid and ive changed tyres no difference and also when turning the wheel wont go back to straight ive got to steer it back. No lights on dash no other faults any ideas anyone??
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Try changing the fluid
    ---Sent from my iPhone 4 using Forum Runner.
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    get the alternator tested power for steering comes directly off it
    May 2011
    sunderland
    Should i check the voltage from the battery because that will show if the alternator is a gonna??
    Regular Member yessof's Avatar
    Jan 2008
    west yorkshire
    Same thing happened to mine a while ago. New battery cured it.
    May 2011
    sunderland
    Did u check what the voltage was on your battery before you got a new one if so what was the reading??
    Jan 2008
    west yorkshire
    I didn't check it. Wouldn't start, AA checked charge rate and battery. Charge rate ok, battery u/s. Fitted new battery no more steering problems. If you connect a multimeter across the battery terminals it should read a minimum of 14.2 volts with the engine running.
    May 2011
    sunderland
    Cheers mate ill have a look after i finish work hopefully its only the battery and not a pump or a steering rack!!!!
  1. Power steering problem
    By Danwells72 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th October 2012, 16:25
  2. On Going power steering problem
    By gazspeight in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2011, 18:18
  3. power steering problem
    By mr.d in forum Vectra C / Signum Car Chat
    Last Post: 9th August 2011, 22:33
  4. Power Steering Problem
    By llaregub in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2008, 11:35
  5. Power Steering problem
    By H11LGX in forum Suspension, Wheels & Brakes
    Last Post: 22nd March 2006, 01:19
