Thread: check safeguard message fault, and computer screen staying on, what can it be?
    newport
    Default check safeguard message fault, and computer screen staying on, what can it be?
    looking to get a preface vec c again, only issue it has is a check safeguard message on the screen. i assume this is related to the alarm. are there any easy ways to find where it is coming from without getting the codes read? or will pedal test show the fault?
    where are the main problems with these? interior sensors? door switches? bonnet switch? or something i havent even thought of?
    possibly related was i noticed sometimes when shutting the door, the trip screen wouldnt turn off, could this be related? other times it turned off fine, is there a sensor in the door which would affect both?
    it would be a shame not to get it for the sake of this problem, but dont want to get it if it could turn into a right pain to sort
    Barrow In Furness, Cumbria
    Sounds like the door sensor to me.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Surely the car wouldn't lock and the interior light wouldn't go off it the car thought the door was open. The fault with my 'safeguard' was one of the terminals to the rear demister being disconnected. I believe it uses the demister element to check if the rear window is in one piece. Just turn on the demister and see if it works. That will eliminate that.
    newport
    cheers, yea all doors lock and unlock fine, and the red door open light on dash goes out with each door shut. good shout on the demister, will check that out
  1. "check light" fault message
    By danhariga in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2012, 15:50
  2. Check Safeguard & Courtesy Light Fault HELP!!!
    By Live2011 in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2011, 01:07
  3. "Check Safeguard" Message
    By Loz2286 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th February 2011, 16:47
  4. the check safeguard message
    By dansri in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2011, 19:15
  5. Flat battery / Check safeguard fault
    By s. buckley in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2011, 20:48
