wheres the best place to wire 4 led marker lights?
Is it like the ones vans and trucks use? If it is, maybe at the jacking point as they're equally spaced from each other both sides
aye its the same but its for the front a was just wondering if i could wire them into the side lights?
Have a look at this thread to see where it's a good point for connecting them up to
something for the weekend (LED Driving Lights) - Page 3
cheers for that. kind fooked ma plans a wanted them to work with my side lights?
that was the original plan but i think i just confused my self. little bit of a blonde moment lol
it says in the thread that if you wire to side lights they will flash untill you turn them on?
Dont you want them on all the time?????
any Led's installed the sidelights or the rear reg plate will flicker as when you turn the car off it auto does a bulb check (flashing led) the current that flows is not enough to light up a bulb, a led uses alot less it flickers it, my reg plate does it but know am sad but i timed it 20-25sec then stays off,
naw just to go on and of with my side lights
