Results 1 to 10 of 13
Thread: outside tmp sensor rubbish
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default outside tmp sensor rubbish
    does anyone else find the temp sensor on a preface a bit naff. mine kept saying F and then really cold temps, so i changed it, sprayed wd40 everywhere, and it still plays up, and gives me frost warnings, especially if its been raining, never had this on the vec b as the sensor was behind the bumper, on this one, its in the lower grille, really exposed, bad design???
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Remove the large multi plug that clips behind the crash bumper, the one where the wires from the temp sensor and foglights all meet. Separate it and check its not got some corrosion in it.
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    is that easy got to from looking down by the rad, think i saw big plug down there somewhere.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 Vtec
    Mileage : 64500
    Yes its easy got to. Looking from the front of the car its down the gap on the right side, between the headlight and rad.
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    think i know the one, cheers mate
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    common occurence for these plugs to be playing up .
    as just give the pins a clean should be ok also make sure none of the wires are loose going into plug
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    this one on the right at the bottom????
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Looks correct to me
    It will have either 2 or 6 wires in -
    1 x Blue (temp sensor +)
    1 x Blue with white stripe (tmp sensor reference)
    and if you have front fogs -
    2 x black (Front fog +12v feed)
    2 x brown (front fog return / ground / reference)
    It looks like your has been modified. - those stray wires running along the bodywork towards the trunking / corrugated tubing.
    I would check the wiring between the sensor and the big plug mentioned above.
    I would also look at all the other added wires inside the corrugated plastic tubing.
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    will do, got to be letting water in i would imagine
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    fitted a new one, unplugged everything, cleaned, loads of blue chalky stuff, all clear now. worked for 2 days, then f and -25, damn, so ive pulled apart, cable tied all the cables to the plugs and cable tied them all behind the slam panel, inc the temp sensor, still work ok there????
  1. why is my t/c rubbish
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 23:46
  2. its just getting rubbish now!
    By twaiter in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2010, 12:35
  3. looks like rubbish....but
    By Wolflinn in forum Detailing and Car Care Discussion
    Last Post: 22nd November 2010, 00:39
  4. OK, since I'm rubbish....
    By davedrinks in forum Introduce yourself.
    Last Post: 11th October 2010, 18:42
  5. Rubbish or ok ?
    By Impresss in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2009, 12:44
