Thread: 12v Permanent Live - Behind the Glovebox?
    Oct 2006
    Yorkshire
    Default 12v Permanent Live - Behind the Glovebox?
    Hello All
    Does anyone have a photo or details of a permanent live that is easily accessible from behind the glovebox?
    I want to install a multi socket 12v adapter thingy to run my Sat nav and Mobile phone charger off ( as I hate using the cig lighter socket because of messy cables !!!)
    My car has the wiring for a phone kit ( assume it's the loom all wrapped in masking tape?!) Can I take a permanent live off there somehow via Scotchlock?
    Any help appreciated
    I'd still run a feed wire back to the ciggy lighter.. you could hide it under the dash trim, all the way back to the gearshift area.. that way you'd get a feed with a decent amperage, rather than tapping into one of the smaller guage signal wires..
    Regular Member cameraman's Avatar
    Leicester
    I've done what Gsi3.2 says, I've put one socket for the sat nav fed off the back off the front charger socket behind the dash & put another socket under the front drinks holder powered of the rear charger socket for my phone.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    There's a nice heavy live behind the glovebox going into the n/s fusebox thats the one i use.PLEASE don't use scotchlocks they give more grief than their worth.
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Scotch locks had an offer on once, free fire extinguisher supplied to every car with one fitted
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    SatNav will run happily of the glove compartment light, I've had two Vec's where I used this feed, running a bluetooth receiver and a PDA from a single feed, you also get the added bonus that this supply gets switched off about 20 mins after you lock the car so there is no danger of flattening the battery if you leave your SatNav in the car, but I would not recommend doing that due to the amount that get nicked.
    I usually pull the conector off the light, put the wires through the holes in the lugs on the light where the connector slides on, then slide the connector back on, trapping the wires, I have never had a problem with the connection like this and if you need to remove the installation, there is no trace of anything having ever been connected.
    Regular Member Orka The Porka's Avatar
    Oct 2006
    North Rochford (The Posh End)
    Scotchlock? Crimp or Solder...It's the law..
  1. permanent 12v live
    By rockafella8587 in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2012, 17:53
  2. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  3. Permanent Live in Boot?
    By bandrew in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2009, 15:03
  4. permanent live
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 17th October 2008, 16:25
  5. Permanent live issues
    By martinbruce in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2008, 13:29
vectra c permanent live
vectra c glove box light permanent live
vectra c glove box light live
in a car is the glove box light permantly live
