Results 1 to 10 of 11
Thread: 314 setup
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    Default 314 setup
    getting on stripping these calipers down
    carrier sliders are out, no rust on them, just greasy, been cleaned down with brake cleaner and a light wire tooth brush.
    piston rubbers look in good condition with no splits or leaks.
    can someone confirm if the rubber boot caps that protect the carrier slider heads are the same size as my standard brakes? as i have noticed one is missing.
    i also intend to fit new nipples and get 2 new brake retaining clips, are these the nipples?
    http://www.ebay.co.uk/itm/1607145925...84.m1423.l2649
    is it advisable to get 4 new bolts to secure the calipers to the hubs?
    One bit of advice , you say that the slider rubbers look.ok but if I was you I'd remove them from the caliper housing clean them properly the get some emery cloth and clean out the holes they sit in
    Basically the holes.gunk.up.and put pressure.on the rubber which stops the.slider working properly
    Also cover the slider in copper grease before you refit it
    Sent from my GT-I9300 using Forum Runner
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Yes the covers are the same for all the front brakes inc VXR. It is advised to get new bolts but I do not think many people do and I have not heard about anyting happening if you don't. To be honest you should not need to change the nipples unless they are worn on the flats. If you do get new ones get them from VX
    May 2012
    northumberland
    Quote Originally Posted by marktaylor View Post
    mark do you mean the rubbers that the cap sits on that hides the slider head mate, or the round rubber that sites around the piston?
    May 2012
    northumberland
    Quote Originally Posted by merikiito View Post
    cheers. i just dont want the garage to runb into any problems, i have been into see them and told them i was going to give them the calipers in the best possible condition i could get them, there was no way i was just going to get these calipers off one car and hand them straight to the garage to fit them on to mine mate.
    i just thought it would be advisable to also replace the bleed nipples.
    May 2012
    northumberland
    also going to be fitting new hel braided hoses, just waiting for the lad on here to get back to me.
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    93172175 part no for bleeding nipples if u need
    May 2012
    northumberland
    u got a number for the retaining clips mate
    36 Post(s)
    Engine : 1.9 DTH
    i will get them in the morning as i have new set still packed with part no on them , they around 10£ from vx
    May 2012
    northumberland
    cheers, local vx dealer is happy to give me trade discount, only thing is they aint part of the trade club scheme (not that these bits n pieces come with the trade club discount)
    but there is another dealer slightly further away who is part of the trade club
  1. Sub & Amp Setup
    By hothatch in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2011, 11:50
  2. 314 mm setup
    By dannysport18 in forum Handling & Braking
    Last Post: 4th August 2011, 18:54
  3. my new 2 din setup
    By kman247 in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2010, 14:58
  4. New ICE setup help!
    By chris_1d in forum Electrical & ICE (including SatNav)
    Last Post: 7th April 2009, 19:15
