Thread: Clutch issue
    Oct 2010
    gloucester
    Default Clutch issue
    Hi All,
    Think I know what the replies are gona come back with but I have a 1.9SRI 120 vectra and today the clutch pedal went straight to the floor with no resistance and didnt return.
    Needless to say the clutch isnt working, im thinking it's going to be the slave cylinder but il welcome any other suggestions before I go down pulling the box out and doing the lot ie dmf clutch and slave cylinder.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Has the brake fluid gone down?
    Oct 2010
    gloucester
    Nope doesnt appear to have im going to try and bleed it all tomorrow with a pressure bleeder im thinking though if I connect up the pressure bleeder and dont release any bleed nipples I should be able to see if theres a leak. Im just really confused that it went from working this morning to bang and it was broken. There just isnt any pressure behind the pedal at all
    Oct 2010
    gloucester
    Almost certain this is the slave cylinder now I put the pressure bleeder on it this morning and before opening the bleed valve and pretty much the entire reservoir for the pressure kit emptied straight away and fluid leaking from the bell housing. had a dual mass rattle for a few months as well so new clutch cylinder and DMF anyone no any reasonable suppliers around Gloucestershire way?
    Oct 2010
    gloucester
    Just bought a LUK clutch CSC and dual mass for £460 from eurocarparts they have an offer on at the moment of 15% of clutch and dual mass use the code CLUTCH15 on there online checkout, you can also use that and select collect from store which is what I did and went and grabbed it 10 minutes later
    Northampton
    Engine : A20DTH
    Mileage : 88000
    You could have used A1 Clutches at Tipton (1 hour up the road from you) who did mine for £650 all in, sorry about the late reply
    Oct 2010
    gloucester
    Oh well win some lose some, im making progress slowly, for anyone thats done this do you completely remove the drive shafts both sides or just separate them from the transmission? and if the latter how do you fully separate them?
    Oct 2010
    gloucester
    grrrrrr Euro car parts gave me the wrong clutch would have had it all done if it wasnt for that, back there tomorrow to exchange it :-(
  1. clutch issue question
    By murf2484 in forum Engine & Drivetrain
    Last Post: 24th June 2012, 20:47
  2. Issue with clutch pedal - any advise please?
    By graded-appliances in forum Insignia Chat (READ ONLY)
    Last Post: 9th October 2011, 14:12
  3. Vectra C 1.8 Clutch/Gearbox issue?
    By ukmgdrooling in forum Engine & Drivetrain
    Last Post: 13th May 2011, 22:57
  4. 1.9CDTI 150 clutch / flywheel issue
    By LGD in forum Engine & Drivetrain
    Last Post: 28th January 2011, 00:29
  5. clutch pedal return issue
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2008, 17:01
