can anyone hepl when you start up she runs lumpy and smokes give a little rev and then all is fine go on a long journey or short park up then the same problem starts all over again
Blue smoke? Mine does that when it's cold. Improved a lot after changing the oil to 10w/40. Might be worth changing the glow plugs too.
Check the swirl bar. My last Vectra (a 150) did this. Discovered the swirl bar was off. If it is, glue them open
Have a look here : http://www.vectra-c.com/forum/showth...-Bar&highlight=
