Thread: brake peddle creep
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default brake peddle creep
    hi all...
    how much peddle creep should i get ?
    although the brakes have just passed a test, i feel that they are a bit soft and i can almost press the peddle to the floor even after iv pumped the peddle up.
    i have just done a complete flush of the system via each calliper to flush the old fluid to see if thats made any difference and it hasn't.
    im now thinking that maybe the seals in the master cylinder and a bit warn after 122k and might need changing or is this peddle creep normal?
    cheers
    al.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by Al 22 dti View Post
    They shouldn't be going down that far.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    if pumped, they should stay almost solid though i think with a tiny bit of creep?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Yes, that's it, there will be a little bit of creep, but not to the degree where they go down towards the floor.
    Sorry I can't help with what the cause might be, but have been in quite a few vectra's and none of them had a pedal like you describe.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    bleedin hell... 180+vat for a new master cylinder...
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    bleed the brake system again before you start spending AL
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    or a used one from a 2007 to 2009 car maybe? if there all the same
    Northampton
    Engine : A20DTH
    Mileage : 88000
    All is fine as long as the following happens:
    1.With the engine off pump the brakes to they are hard, they then should stay hard and not drop
    2.With the engine running the brake pedal will drop to the floor after being pumped, this is normal
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by merikiito View Post
    and that's exactly what happens. I think I might of been looking at it wrong or maybe never noticed it as much.
    Many thanks all.
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    If the ignition is on the ABS system sees the wheels not moving and reduces the pressure in the system and the pedal will drop to the floor the real test as Lee says is ignition off the pedal should be solid as the ABS system is inactive.
  1. Brake pedal creep - 2.0T - MOT failure!
    By Gus93 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th June 2012, 20:40
  2. Single Tap On Pressing Brake Peddle
    By treadstone in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2011, 23:49
  3. Brake pedal creep Signum 2.0T (not diesel)
    By olajon in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2010, 12:13
  4. Peddle covers?
    By the stig in forum Vectra C / Signum Troubleshooting
    Last Post: 30th September 2009, 15:38
  5. MOT fail due to brake pedal creep
    By baztheman in forum Suspension, Wheels & Brakes
    Last Post: 18th March 2009, 15:26
vauxhall vectra c 1.9cdtI brake.pedal creeping
