Page 1 of 17 12311 ... LastLast
Results 1 to 10 of 164
Thread: Making BC work with stalk controls
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    confused Making BC work with stalk controls
    Yep I no what ya mean think I have found away to keep bc with the ncdc gone well after some advice of two nice memeber
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Quote Originally Posted by paulvectrac View Post
    That sounds interesting.. will to tell
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Modesty prevents anything being said.
    The names of all persons involved have been changed to protect the innocent - ha ha
    So it works then?
    Engine : 2.2 Direct
    Quote Originally Posted by Robsey View Post
    So it works then?
    come on
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    And............ Yes it does work Robsey thanks very much matey
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    I have to say that I thought it should work, as the NCDC2013 was an original fit in this car, so all the wiring etc was also correct.
    maybe there is a minor issue when retro-fitting NCDC units, that every wire MUST be present and correct for the BC switch to work.
    Thr BC switch programming is a standard Variance configuration item.
    For some reason, my brain won't tell me whether it is in the DIS and/or the CIM modules.
    A quick look in both sets of module tables would answer that question, when programming.
    Engine : 2.2 Direct
    Well let mé know more anyway.... As i know every wire is present in mine and correct....
    So what setting to change just to try it out. (I know it Wont work if i remove the adaptor loom, unless i change in the oem loom.)
    But does the bc now work ón the buttons or did you put in a stalk with the buttons.
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    He put in a stalk with the buttons, and then showed it as present in the variance config settings.
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Try it with my mates car tonight who's ncdc is retrofitted and it didn't work mine was factory and it works hmmmmm strange
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    O it was retrofitted by me aswell
  1. Aftermarket Stalk Controls
    By T4M in forum Parts for sale
    Last Post: 11th October 2008, 21:11
  2. Trip computer/stalk controls
    By nikroc in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2007, 07:58
vectra c phone portal
2005 vectra 1.9 cdti bcm and cim fault
vectra c canbus decoder loom
opcom body bcm doors unlocking function
vectra c steering wheel controls not working
vectra c cid work with stalk control
retrofit vectra c info stalk
vectra c inclinat sensor
