Thread: Signum 2.0l dti Problem! (Clutch?, Linkage?, WTF?) [Help!]
    Apr 2012
    Ma Hoose!
    Default Signum 2.0l dti Problem! (Clutch?, Linkage?, WTF?) [Help!]
    Hi All,
    Parents went out on Sunday drive, which turned into a bit of a nightmare.
    They have a Signum 2.0 DTi Elegance on a 54 plate, they were on the way home when the car became laboured, but the engine ran and sounded fine but the gears became hard to select and the power simply was'nt being transferred to the wheels?
    There were no warning lights, no limp mode activation, no weird noises, no smoke and no smell. The car became so slow he had to pull into a lay-by and call the AA.
    When the AA got there they also could not find anything expect that the car would now not engage any gear.
    I got to their house today to check it out and this is also what I found; The car turns over just fine, the neutral idle is fine, but when you try to engage a gear it is very difficult, when you eventually move the stick to a gear and let out the clutch nothing happens... there is not even any indicators that you have selected a gear as you leave out the clutch (such as; noises or vibrations or attempts at movement)
    Hope you guys have some knowledge to drop, it would be much appreciared!
    Regards,
    Jack.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Sounds like it needs a new clutch
    Had an identical fault on a fiesta I had a few years back. Needed clutch and flywheel.
    ---Sent from my iPhone 4 using Forum Runner.
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    pop the linkages off at the g/box end and just check they move freely when some one moves the gear stick if not plenty of WD40,then if not it sounds like tony said gearbox out to investigate slave cylinder and clutch, hth
    Apr 2012
    Ma Hoose!
    big Tee, Pardon my lack of knowledge but what could have ceased at the g/box end of the linkage?
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    sorry for delay mate i work 12hr nights... sometimes the cables seize up this is a really common fault on corsa s its a 2 minute job to check its a ball and socket connection at g/box end..if you move the levers on top of the g/box you can put the car in gear with the cables not connected its worth a try before a box out job..but to be honest i think you may have a goosed slave cylinder or clutch
  1. Front Wiper linkage problem
    By craig20102010 in forum Bodywork & Interior
    Last Post: 26th November 2012, 18:02
  2. Clutch problem
    By guvnagra in forum Engine & Drivetrain
    Last Post: 30th September 2011, 11:49
  3. Wiper linkage problem!!!!1
    By saga10 in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2010, 20:51
  4. Signum clutch problem
    By HONESTJOE in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 15:40
  5. Clutch linkage
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2009, 14:32
