Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Tech2 sequence auto light
    Nov 2011
    Valkenswaard
    Question Tech2 sequence auto light
    I retrofitted a rain sensor EX and a switch with a auto-position for autmatically switching on my headlights.
    The rainsensor works fine, but I can't program the autolight function.
    My Tech2 says "not available" on the autolight sensor item in the BCM programming mode. When entering this item it says it is "fixed" and cannot be programmed.
    What should I do? or what is wrong?
    I'm a Tech2 novice.
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I bet u havnt got reall tech 2 have you that's ya problem mate I have reall tech 2 and I never have problems well I do ATM mines spat it's dummy out
    Nov 2011
    Valkenswaard
    I've got this one
    Admin plasma's Avatar
    On the Forum
    181 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by Jerom747 View Post
    I'm a Tech2 novice.
    If its not available then it means the BCM does not support this function, you will have to find another BCM which supports the autolight function
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Fair play fella it's reall fpmsl u must have money to burn lmao
    Nov 2011
    Valkenswaard
    Quote Originally Posted by plasma View Post
    Do you know which BCM (GM partnumber, ident) I need for this?
    The one fitted now is GM 13193590
    Nov 2011
    Valkenswaard
    Quote Originally Posted by paulvectrac View Post
    Hi Paul,
    My english isn't that well that I understand "fpmsl" and "Imao". Sorry.
    On the Forum
    181 Post(s)
    Engine : 150
    Mileage : 74000
    will have a look tonight and see what your best option for the BCM replacement is..
    Jun 2006
    St. Helens,Merseyside
    Hi Paul,
    F P My Sides Laughing
    Laughing My Ar-e Off
    hope this helps or HTH
    thats a nice looking tech 2, is it the genuine GM or a Chinese copy do you know?
    Full Member andy.l's Avatar
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    have you also programmed the rec and the uec (fusebox)
    as these will also have to be programmed
    2011 insignia elite tourer 2.0 cdti 160 manual,silver
  1. Tech2 sequence for adjusting wheel/tyre diameter
    By Jerom747 in forum Bodywork & Interior
    Last Post: 15th October 2012, 12:52
  2. help with tech2 programming auto AFL
    By emsedk in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2012, 16:54
  3. Auto lights/Dimming Mirror Tech2 Procedure
    By Aidi in forum Electrical & ICE (including SatNav)
    Last Post: 27th April 2011, 21:19
  4. Tech2 Rain sensor and auto headlights...
    Last Post: 16th July 2010, 20:33
  5. Installed auto dimming mirror... Tech2
    Last Post: 17th January 2009, 16:13
programming vectra c rain sensor site:www.vectra-c.com
vectra c tech2 auto light
