Results 1 to 10 of 15
Thread: Next doors vec dti
    Jul 2011
    UK
    Year : 06
    Default Next doors vec dti
    Next door has a 52 vect dti sri not sure if its the 2.0 or 2.2 anyways she had the egr cleaned a couple of days ago and this morning I heard it starting n sounding rough then cut out she tried it several times and kept cutting out my dad last night asked if I could have a look anyone have any ideas
    Sent from my Nokia 3310
    Club-Vaux Admin
    Engine : 1.9 cdti
    Mileage : 145k
    check the vac pipes & leak off pipes
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by bensterzback
    That's the 1st thing I thought but then thought that wouldn't make it cut out didn't on my cdti anyways
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    leak of pipes can make it cut out if there letting air in quite bad on first start up
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    As above on the pipes, check the pipes above the egr to make sure none have been damaged .
    And also look for signs of fuel leaks in the same area ,
    Failing that then its probably best to have the codes read
    and still loving it
    Jul 2011
    UK
    Year : 06
    Cheers guys where are the leak off and vacumes on these engines are they at the rear
    leicester
    Trim : Sri xp2
    Mileage : 100000
    hi leak of pipe are right at the front of the engine im sure theres a how to on here.
    Engine : 2.0DTi
    Mileage : 73350
    DTI engine layout 2.jpgDSCF0003AA.jpgDSCF0002AA.jpgDSCF0001AA.jpgpic 1001 vacuum hose.jpgMarc the leak off pipes on these engine are at the front of block , find the 4 fuel inlet feed,s silver in colour 2 each side of the egr and the leak off pipes will be next to them (Visible in pic 5 between inlet manifold and camshaft cover)
    For the vacuum pipes go to right hand side of the engine (looking from the front ) there will be a circular shapped object with two pipes coming off it this is the vacuum pump the thinner tube that comes out from the bottom is your vacuum feed from there they split out to the solenoids on the bulkhead above the radiator
    and to the turbo and manifold . Can not give an exact description as they vary between models and year of manufacture and also where it was made (the other picks show you the vacuum hose setup in this case for a 2.0 DTi with tps )
    and still loving it
    Jun 2011
    wolverhampton
    It won't be the pipes it's the anti shudder flap not opening on start up. It's either faulty valve or the flap is jammed. Pull the pipe off that tucks just under the front of the engine cover that goes to a little vac cell just after the boost pipe hose goesto the throttle body. Block the hose off after and car will drive perfect but will turn off with a shudder shake. You can just about reach the pipe with the cover still on. If it's just the vac side of it that's holding it shut you will hear it clunk open when u pull the pipe if not push the linkage with your finger if it's jammed with soot and carbon. It's the pipe in the last picture in the post above and you can see the linkage there aswell.
    Jul 2011
    UK
    Year : 06
    Thanks for the info and pics guys al look at it tomorrow just finished work should be able to sort it thanks again
  1. Looking for some 12v in the doors
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 6th September 2012, 22:17
  2. Taxi Doors / Autolocking Doors
    Last Post: 17th April 2012, 19:05
  3. 4,,, Or 5 doors??
    By mitch1965 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2008, 19:56
  4. How do you take the doors apart?
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2006, 20:28
