Results 1 to 10 of 14
Thread: Thoughts on a missed service 2.2 signum
    Sep 2012
    Norfolk
    Engine : 1.9 CDTi 150
    Default Thoughts on a missed service 2.2 signum
    You opinions please. Looked at a 2.2 signum last night on a 56 plate. The owner bought it in jan 11 at 22k, drove it till 39k, missing a service at 30k, by which point the can chain was noisy. He then had it serviced at 39k and new chain.
    It sounded healthy but would this lead to other engine problems?
    Also the drivers seat looked tired for 40K, is this normal for leather? Looking at the seat i'd have expected to see close to 100k on the clocks.
    Other than that looked very nice. It's the lack of service which is putting me off and possible engine damage.
    You have doubts about this specific car, so don't take any further interest
    With respect to the issues you have raised
    A missed service is not the end of the world
    Warranty companies, once you make them aware of this, will request you apply a process called clawback
    This will mean a few services in a shorter than normal period, and will then put the original schedule back in place
    With respect to this vehicle, the services would have been due in 2008/2009, 2010/2011, and 2012/2013
    It is therefore now due its third service, so has one service missing
    Taking it to 39K miles is rather high, but so long as the pollen, air, and fuel filter were also replaced there is no major issue
    The main issue would be the oil and oil filter, and this may have resulted in the engine damage, of which the noisey cam chain is one symptom
    The entire issue would need to be investigated, as other components will have worn excessively (not just the cam chain)
    It would be rather unusual for the drivers seat to have worn by 5 years old / 40K miles
    This suggests lots of short journeys, almost every day, most likely from commercial use (including taxi)
    Equally, it could also be an indication of clocking
    When the seats show such wear compare other items that should wear out at roughly the same rate such as the clutch and brake pedal rubbers, and the protection mat (often hidden under carpet mats)
    If the service book only has one stamp, as suggested above, then this would be one way to hide the history
    However, the car should have at least two MoT, so you could check these to see if the mileage is consistent
    With a good third party warranty subsequent engine damage will not be an issue over the period of cover, but don't expect the car to last as long as if it had a full and correct service history
    It has probably lost about 50% of its engine life, so expect it to have further issues from 100K miles onwards
    The other car components won't be an issue or concern as they are most non-maintenance and will fail as normal with wear and tear, but as above if it has indeed been clocked this will occur unusually early on the currently indicated mileage
    As above, don't look any further into this car...
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 129000
    problems with fuel pumps and regulators on the 2.2
    http://www.vectra-c.com/forum/showth...direct-misfire
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 129000
    Regular Member ijk571's Avatar
    Jul 2011
    UK
    As M8internet said, steer cleer!!
    Quote Originally Posted by Paul_B View Post
    Shouldn't do. After all the official service interval is every year OR 20,000 miles - whichever comes sooner. In short, it hadn't done 20,000 miles since the last service, but had been more than a year.
    My leather had done nearly 80,000 miles and still looks like new. End of the day it depends on how you look after it. Clean it regularly and feed it every now and again to keep it suptle and it'll last years.
    Sep 2012
    Norfolk
    Thanks for the comments, I'll be giving this one a miss. If nothing else then it opoints to the car not being looked after.
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    The outside of the driver's bolster is prone to wear and it's a common issue, partly due to the fact car companies are too cheap to use actual leather on anything but the seat faces and a lot depends on how the driver gets into the car and the seat position, etc.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Surely also the state of the leather would also be dependant on the weight of the driver, if the guys 24 stone he is not going to be jumping in and out of the car he is going to be pulling himself in or out and as such sliding across the seat surfaces .
    No offence intended to anyone but this is a fact i had a freind who was on the large side and he broke two of my car seats just by getting in and out
    and still loving it
    Trim : GSi
    Mileage : 39k
    Exactly.
  1. Thinking about a Signum - some questions & your thoughts requested?
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2011, 16:10
  2. want to add satnav to signum any thoughts
    By scou5er in forum Electrical & ICE (including SatNav)
    Last Post: 8th March 2010, 01:41
  3. Signum Service with DPF
    By bandrew in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2008, 23:28
  4. 1.9 Cdti signum. My thoughts
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 27th March 2007, 18:54
  5. Signum - First Thoughts
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2007, 22:19
