Thread: vectra dti fuel
    Jan 2010
    norfolk
    Default vectra dti fuel
    hi my vectra dti 2.0 on 53 plate uses to much diesel , i put£10 of diesel in and it only got 44 miles to the tenner on a run , also temp gauge sits at 80 while driving and in traffic will go down a bit , do i have to change whole stat housing or can i change just thermostat any help thanks
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    based on 141.9 for diesel that comes back as 28 mpg , seriously bad .
    shouldn't think the temperature being at 80 would be a problem .
    Club-Vaux Admin
    Engine : 1.9 cdti
    Mileage : 145k
    when was it last serviced ? has it ever had the inlet / egr cleaned ?
    Jan 2010
    norfolk
    hi yes iv had car over a year and cleand inlet and put new egr on not long after i got it , woulg changing cts sensor be any help thanks
    Sep 2010
    north east uk
    Quote Originally Posted by octoman View Post
    They are only a few quid m8,so maybe a good place to start?
    i changed mine not long ago but not because of excessive fuel consumption.
    Jan 2010
    norfolk
    would faulty cts sensor cause bad fuel consumption and is there a way to test sensor thanks
    May 2012
    county durham
    Mileage : 145k
    yes it could , best way is to get the car on diagnostics & check for fault codes , then go into live data & see what temperature the ECU thinks the engine is at .
    Jan 2010
    norfolk
    hi thanks dti elite , i have been for run and got upto temp of 80 dgrees put op-com on and it read the same as temp gauge , there was no fault codes present , would this still mean cts is still faulty
    May 2012
    county durham
    Mileage : 145k
    try checking it from cold & see if the reading is roughly the same as the outside temperature ( give or take a few degrees either way )
  1. vectra dti fuel prob
    By octoman in forum Engine & Drivetrain
    Last Post: 13th January 2013, 23:43
  2. vectra dti fuel problem
    Last Post: 27th March 2012, 21:58
  3. 04 ZC Vectra 3.2 Bad Fuel Economy
    By marsupial in forum Vectra C / Signum Troubleshooting
    Last Post: 6th March 2009, 02:11
  4. Vectra c 2.2 sri seems to be using more fuel
    By daveloz1 in forum Engine & Drivetrain
    Last Post: 27th December 2007, 19:31
vdctra dti live data
