Results 1 to 3 of 3
Thread: Big knocking noise from front
    DERBY
    Default Big knocking noise from front
    hi,
    having changed the drop links a week ago the knocking noised went away, now i have a big knocking, it sounds like something is hitting the bulkhead!!!!! and the passenger side wheel is hitting the inner wheel arh!!!!! i don't understand what is going on.... Any help would be great.
    cheers
    Sodding Typical on Sea
    Have you done a visual inspection, as it sounds as though one of the drop links has worked itself loose from that description either that or a spring has let go after the release and re tension on the lift.
    Nov 2010
    East Midlands
    Trim : design
    Are your wheel nuts tight
  1. Knocking/Clunking noise from front suspension
    By MrDerv in forum Suspension, Wheels & Brakes
    Last Post: 21st April 2012, 17:14
  2. Knocking noise from Front Wheel
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 08:14
  3. Knocking Noise from Front
    By mark1319 in forum Suspension, Wheels & Brakes
    Last Post: 12th February 2008, 15:54
  4. Front knocking noise over speed bumps
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2007, 08:25
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
front passenger side vectra knocking noise going over bumps
vectra c knocking noise from front
