Thread: boost sensor help?
    Regular Member tiimi's Avatar
    Sep 2012
    anglesey, uk
    Default boost sensor help?
    about 2 hours ago i followed the how 2 clean boost sensor. the pics of engine where different to mine as my egr valve assembly was directly behind the scre for the boost valve. i had to take the 3 bolts out of the egr valve bracket, and also the 2 bolts from the elbow joint of the egr to allow me access the boost sensor. the sensor was absolutely full of s**t. any way back to the point. put everything back and now when i turn my ignition on, the spanner light comes on, but then goes out when i start the car ??? is this ok ??
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Have you checked the elec plug to the egr is not disconnected.
    Jul 2011
    UK
    Year : 06
    If I remember the spanner light does come on with ignition anyways then goes out when u start it if it stayed on while u started it that means there is a fault
    scottish region
    as said the light comes on and goes out its normal as long as it goes out it will be fine
    Sep 2012
    anglesey, uk
    i just didnt notice the spanner light before hand !? maybe because i wasnt looking for it. well yeah thanks for info. and car pulls a lot more now. more oomph. will do egr valve when i get some tools
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    You have the 120bhp engine - same as mine (oil cap on the left from the front) - that's the main difference on the sensor cleaning how 2 between the 150 and 120. I did the egr and boost sensor at the same time since i had to take the EGR off anyway... It's a nice little difference when its clean huh?
    Stuart
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved to correct section !!!
    Irmscher Insignia CDTI 130
    Feb 2007
    airdrie
    just doing my egr and boost sensor as well as the new silicon pipes at the vacuum . the boost sensor is caked in crud ( polite version) and my EGR which i had renewed 6 months ago is totally caked .. cars been a tad sluggish and jerky lately so hopefully this was the problem
  1. Boost Sensor & 10K Boost
    By hebdendave in forum Diesel Engine related
    Last Post: 13th February 2011, 17:43
  2. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  3. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
  4. BOOST SENSOR, where can I get 1 and how much?
    By VXR CDTi in forum Diesel Engine related
    Last Post: 12th November 2008, 16:20
