Results 1 to 10 of 11
Thread: new thread - same issue - BATTERY LIGHT!!!!
    Regular Member SarahP's Avatar
    Nov 2011
    Buckinghamshire
    Default new thread - same issue - BATTERY LIGHT!!!!
    Ok new thread.. just a quick reminder, had new alternator fitted July this year after losing everything & battery light came on, fitted all good..
    In August (6 weeks later) battery light came on again, put on replacement alternator... all good!
    Ironically 6 weeks later AGAIn.. ****** battery light... bear in mind it comes on and stays on, when I turn engine off and on there is no battery light, we did a 25 mile run after (no light).. few more days running about then light came on again & syated on, turned engine off and on (no light) did another 20 miles and no light.. this morning i decided to do some readings
    no engine on :12.3v
    started car this morning, readings were as follows:
    Engine running: 14.34
    " but with everything on: 14.23
    turn everything off again: 14.30
    drove down to school battery light came on, as I kept reader with me I checked it whilst the light was still on & engine still running it showed :14.34!!
    took my 2 youngests into school and drove home (no light) pulled on drive and took readings again (still no light) -
    engine running only: 14.34
    with everything on: 14.19
    turn everything off except engine: 14.26, 14.27, 14.28 (then I turned engine off)
    now with my head in the engine (not literally!!) i looked at belt going round and it seems fine, (its tight when engine is off) I could 'faintly' hear squeeking/chirps, but cannot hear that at all in the car...
    what u think now?? its doing my head in!
    I have 1.9cdti (120) estate 54 plate.. the 2 alternators recently fitted are both from Euro Car Parts and I 'think' it was the 110amp (i could be wrong)
    Dec 2011
    Seaham
    Either there is a problem with the alternators or you have a break/fault in the wiring? I would suggest taking it to a good auto electrician to have it checked over.
    Nov 2011
    Buckinghamshire
    thank you Ben, its such a mystery!
    Aug 2012
    South Wales
    Have you tried the connections first for corrosion both on the alternator and the bat although you getting a goog reading it only takes one drop for the light to come on and stay on till you turn off and on again also check the belt pully is right to mate
    Nov 2011
    Buckinghamshire
    belt pulley? is that the round things that the belt goes round on? if so how do I check that?
    Regular Member graham a's Avatar
    hull
    sarah,the thin wire coming off the alternator is the charge wire,and should be a negative.i would check here and see what the voltage is.check this drawing,it should give you some idea
    http://www.google.co.uk/imgres?q=car...18,s:322,i:156
    Nov 2011
    Buckinghamshire
    do i put the negative probe from the reader to this wire then and do I check it with the engine off or on? ..
    hull
    first of sarah,check the connections at the alternator.then proceed with a voltage check,with the engine OFF.then see if you can get a voltage test at this connection,with the engine running.can i say be very careful when the engine is running,where your sticking your hands .what type of meter are you using sarah,as a multimeter would be best
    Nov 2011
    Buckinghamshire
    it is a yellow multimeter with red and black leads
    hull
    Quote Originally Posted by SarahP View Post
    let us know how you get on.doing work stuff,but will keep a eye on your thread
  1. Cold start issue - Thread 1,426
    By Barlow in forum Vectra C / Signum Troubleshooting
    Last Post: 30th August 2012, 18:29
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. Battery issue.
    By Collis in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2012, 22:38
  5. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
