Thread: Rubbing noise from rear wheel
    Berkshire
    Default Rubbing noise from rear wheel
    I was hoping someone might have an idea what this could be. I'm driving a 2008 model with 25k on the clock (never had pads or discs changed). I've had it since 4k and I'm very light on the brakes, usually slow down using the engine or gears.
    I've got this noise coming from the rear wheel which sounds like 'whoosh whoosh' when travelling slowly even when not braking. The slower I go, say 2mph, the time between the noises gets bigger, making me believe something is stuck on the pad or the disc. But, surely it wouldn't do it when not braking?
    I've got an MOT on monday, so hoping its ok until then or would you advise getting it in ASAP?
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    have you gave it a visual inspection, try rotate wheel when off the ground see if you can feel anything, backin plate, something wrapped around the hub? i cant see it been anything serrious on such a low milage car.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    Quote Originally Posted by mike rb View Post
    i was hoping someone might have an idea what this could be. I'm driving a 2008 model with 25k on the clock (never had pads or discs changed). I've had it since 4k and i'm very light on the brakes, usually slow down using the engine or gears.
    I've got this noise coming from the rear wheel which sounds like 'whoosh whoosh' when travelling slowly even when not braking. The slower i go, say 2mph, the time between the noises gets bigger, making me believe something is stuck on the pad or the disc. But, surely it wouldn't do it when not braking?
    I've got an mot on monday, so hoping its ok until then or would you advise getting it in asap?
    what make are the tyres?
    Berkshire
    I've used a torch mirror on a stick to give it a visual inspection but not raised the wheel from the ground yet.
    Tyres are Kumhos. Been on the car for around 6 months.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    there is a similar thread running on this
    http://www.vectra-c.com/forum/showth...rear-n-s-wheel!
    mine was the tyres you could try swapping the fronts to the back for cheap fix
    what make are the front tyres ?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    http://www.vectra-c.com/forum/showth...light=dronning
    as i say check the tyres
    i bought 4 goodyear excellence in the end and the dronning went
    i need to buy two more now for the front as they have done 22000 miles on the fronts
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    Berkshire
    Thanks all but it sounds like something is rubbing as you can hear it as the wheel turns. ie. it seems to get to a point on the wheel and make the sound then as the wheel turns and reaches the same point, it makes the sound again, like its a specific point on the disc or wheel that rubs rather than a constant sound. I dont think I'm explaining it very well.
    Berkshire
    The noise appears to be getting worse. Pretty much constant when moving. I made it worse by stamping on the brakes (in a safe place). When I moved off, it was much worse. Got home, jacked up the wheel, and it doesn't rotate freely (seems to rub on the pad which seems to be touching the disc). I then took the wheel off and couldn't see anything obvious. However, I then jacked up the other side to check if it felt better and that also seems to rub the pad when spinning the wheel. So, I'm stuck on this and going to have to take it to the garage for it to be looked at.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 135000
    ian highlander quoted the little guard behind the disc that sits up against it behind the lower ball joint. You can see if if you look round the back of the wheel, just tweak it out a few mm with a screw driver and the squeal will go. Very common on the Vecs.
    it may be that
  1. Rubbing noise nsr
    By pipamish in forum Suspension, Wheels & Brakes
    Last Post: 27th December 2011, 01:05
  2. Rubbing Drone noise front wheel
    By baluachrach in forum Suspension, Wheels & Brakes
    Last Post: 30th May 2011, 09:45
  3. rubbing noise?
    By Messenger in forum Engine & Drivetrain
    Last Post: 24th February 2009, 21:21
  4. Rubbing noise
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2007, 23:56
  5. rubbing noise from rear
    By robinhood66 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2007, 16:35
rubbing sound on vectra
vauxhall vectra rubbing noise from wheel
