Results 1 to 10 of 16
Thread: Still no power................
    Mar 2011
    belfast
    confused Still no power................
    Hi everyone,
    as the title says, STILL NO POWER.
    i still havent got to the bottom of this prob with my 1.8 vvti (z18xer).
    see my earlier thread = NO POWER.
    im not going to let this prob beat me though,
    im now getting 4 codes.
    1, 0014 = camshaft position, timing over advanced or system performance bank 1
    2, 0564 = cruise control system malfunction.
    3, 0420 = catalyst system, efficiency below threshold, bank 1.
    4, 0621 = generator lamp "L" control circit malfunction.
    0420 = catalsyt system, is a new one to me on this prob.
    im now wondering is the fuel trim off as it would effect the cat.
    i read on a volvo site "VOLVOSPEED" that this 0014 prob was cured by replacing the FUEL PRESSURE REGULATOR on a s40.
    does the the z18xer have one of these, if so, where???
    Dec 2011
    Seaham
    Are you sure 0014 refers to bank 1?? I think you will find it relates to Bank 2 which is the exhaust side. I still think you have a problem with either the cam phaser solenoid or the cam position sensor?
    Check your codes on here.
    http://www.obd-codes.com/trouble_codes/
    Mar 2011
    belfast
    hi ben5on,
    i had a look at that link,
    0014 says bank 1
    0021 says bank 2.
    i had the car out earlier and when i put some fuel in it, it got a lot worse.
    but when i drove it an hour or so later it was slightly better but still no power when needed.
    FUEL FILTER????????????????????????????????
    IT BETTER NOT BE, or ill hit myself with something lol,
    but i have not changed it in over 40k.
    worth a try.
    Engine : 1.9 CDTi
    Quote Originally Posted by gstore View Post
    worth a try.
    Do you not service your car?
    Dec 2011
    Seaham
    P0014 is Exhaust CAM Phaser, if you clicked on the link it explains that Bank 1 has piston number one in it, and B cam is the exhaust, have copied and pasted as below
    A code P0014 refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module, also called an ECM). That consists of a few different components but the P0014 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is above a set limit (over-advanced), the engine light will be illluminated and the code will be set. Bank 1 is the side of the engine containing cylinder #1. The "B" camshaft shall be either the "exhaust," "right," or "rear" camshaft. Left/Right and Front/Rear are determined as if viewed from the driver's seating position.
    I had both error codes on mine, I replaced the A bank one, the inlet and this left the B bank fault until I replaced the exhaust cam solenoid.
    Mar 2011
    belfast
    at long last, problem solved.
    seeing i got the code 0420, catalsyt system, efficiency below threshold, bank 1.
    i decided to take of the cat and replace it with my old one from my old engine which i removed the cat from.
    once i took it off, the cat inside was in pieces and fell out from the top end so it must have been choking the engine as all power is now back.
    ok, i know it wont pass an MOT but it just went through PSV last week so ill worry about it next year.
    thanks everyone for all advice.
    Mar 2011
    belfast
    Aug 2012
    cardiff
    I have 2 coeds and dont no what they are p 0070 and p 1109 could any one help me plz and tell me what i need to change thanks
    Mar 2011
    belfast
    What car do you drive and what engine type?
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    P0070 Ambient Air Temperature Sensor Circuit
    The P1109 for your car will mean one of these.
    P1109 Swirl Actuator Malfunction B-033
    P1109 Swirl Actuator Supply Voltage Range/Performance B-033
    P1109 Swirl Actuator Feedback Circuit High Voltage B-033
    P1109 Swirl Actuator Feedback Circuit Low Voltage B-033
    P1109 Swirl Actuator Feedback Signal Malfunction B-033
    P1109 Swirl Actuator Feedback Signal Range/Performance B-033
    P1109 Swirl Actuator Feedback Powerstage High Temperature B-033
    you need to check your swirl flaps first off
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Signum Sluggish low power, Limp mode at high power.
    By Bigg943 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th June 2011, 18:55
  3. Signum Sluggish low power, Limp mode at high power.
    Last Post: 5th June 2011, 11:30
  4. Replies: 11
    Last Post: 7th January 2010, 17:50
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
