Results 1 to 10 of 13
Thread: Any ideas/sudjestions at Whits end with it now
    Aug 2012
    South Wales
    Default Any ideas/sudjestions at Whits end with it now
    Hi all as title says had enough now throwing money at my cdti 150 and still got same prob bad stutter at around 1250 rpm when pulling up hill it feels like it stalling and can clearly see the revs dropping off best way to describe it as being in to hire a gear that type of judder but when she drops to below the 1250 mark she pulls fine I done loads so far and just don't know where to go next things done so far
    full service
    new inlet man
    new egr
    egr blanked
    new bcs pipes
    cleaned bcs
    new thermostat ( broke anyway)
    new alternater aux belt and bat they died
    injector 3 and 4 wiring replaced
    10k boost cleaned
    forty fuel treatment
    boost control solenoid cleaned
    throtle body cleaned and circuit board checked all ok
    any and all ideas would be appriciated
    the only codes I am getting is p0400 but egr is blanked so I think that right thanks in advance all hope you can help
    Regular Member jsnlvxr's Avatar
    wiltshire
    maybe worth getting injectors tested?
    Aug 2012
    South Wales
    Would I get any more info off a live reader
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Re circuit board on throttle body , get them redone anyway in case U can't see dry / cracked joint ..., has ur car got dpf ?
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    hope you get this sorted mate your head must be done in now, sorry i cant help you with anything.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Swirl flaps ???
    Aug 2012
    South Wales
    Not got a dpf and the swirl flaps are new new inlet man
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Did you change the swirl flap motor and have you check they are moving. Grt someone to rev the car while you look where the bar is and you should see them move
    Aug 2012
    South Wales
    Ye all working fine would a live data code reader show up injector probs
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    If you can see injector duration it may give indication
  1. Anyone got any ideas
    By paulvectrac in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2011, 16:42
  2. Ideas Please
    By Tomb in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2010, 16:21
  3. Any Ideas ???????
    By johnnyd2003 in forum Engine & Drivetrain
    Last Post: 16th April 2009, 21:13
  4. Any ideas as to what this is
    By Baz07 in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2008, 21:21
  5. Any Ideas?
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2008, 16:49
