Thread: brake bleeding
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default brake bleeding
    can i gravity bleed the system?
    the fluid in the reservoir looks a bit black and i think it needs replacing.
    can i just open the bleed nipples and let gravity work or do i need a special bleeding kit/tool?
    al.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    You can open the nipples and pump the peddle that will push all the fluid out the pipes but i would put rubble pipes on the nipples in bottles or something you dont want brake fluid all over the place.
    Edit: But you will need a bleeding kit to put the new fluid back in the pipes unless you do it the old fashion way and pump the peddle to bleed them.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Get a brake bleeding kit that has a one way valve on it and a catch tank, makes the job a lot easier.
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    15 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    If its a one man operation id use a GUNSONS EAZIBLEED.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    simple bit of pipe block one end off and cut a small slit in it, push the open end over the nipple and the blocked end in a bottle and pump away on the pedal it will stop air sucking back in to the lines
    just make sure the fluid does not go below the minimum line
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    cheers lads... it looks like a bit of pipe blocked off with the split is in order!
  1. Brake fluid bleeding
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2012, 13:28
  2. Brake bleeding..
    By macdad in forum General Motoring Chat
    Last Post: 10th July 2012, 07:30
  3. Draper Brake Bleeding Kit - Anyone used it?
    Last Post: 16th December 2010, 20:33
  4. Brake problems, Bleeding, Warped Disc?
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 24th December 2009, 13:56
