Thread: F40 Gearbox Whine
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default F40 Gearbox Whine
    I posted here a few months back reference my Z20net gearbox being notchy in 1st and 2nd gear changes and a rattle on idle with it disappearing when clutch pedal pressed.
    Well over the past couple of months this problem is slowing getting worse i can hear a rattle coming from the centre console area when i pull away in 1st and go for 2nd when clutch pedal pressed and also when in 3rd travelling at 30mph and release accelerator pedal upon decrease in speed thats when i hear the whine i dont hear it when accelerating and its not all the time in every gear just 2nd and 3rd.
    A few weeks ago i took a drive to Borth to see my brother and on the way back i was travelling in 6th gear and if i was to press accelerator pedal quick i hear and feel and loud thud like engine or gearbox moves, the car still drives great other than this problem and im not sure what it is the car is a facelift 2005 2.0 Turbo with 52000 on the clock, just a little concerned can someone please help
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Could it be the clutch, sounds like the clutch slave cylinder is knackered
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Quote Originally Posted by merikiito View Post
    The clutch feels ok I don't get any slipping etc but I do think it won't be long before I need one
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by pipamish View Post
    Just because the clutch is not slipping it doesn't mean that the clutch slave cylinder is knackered
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    What actually does the clutch slave cylinder do ?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Its number 9 here: http://opeloem.com/vauxhall/vectra_c...lutch_kit.html
    The master clutch cylinder is attached to the clutch pedal. When one depresses the pedal hydraulic fluid is forced from the master cylinder through the hard line to the slave cylinder. The piston in the slave cylinder is driven against the clutch linkage thereby releasing the clutch.
    they can start to rattle and leak fluid stopping you from getting it gear or some gears
    South east
    Separates the clutch from the gearbox so that you can change gears cleanly and without crunching.
  1. m32 gearbox whine.
    By frasedeb in forum Engine & Drivetrain
    Last Post: 30th November 2012, 10:20
  2. Vectra 2.2 petrol elite gearbox whine, I think......
    By pt9091 in forum Engine & Drivetrain
    Last Post: 12th May 2012, 09:41
  3. gearbox whine???? not sure
    Last Post: 21st April 2012, 19:43
  4. Gearbox Whine - Which Box Code?
    By Bobster691 in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 07:51
  5. vectra c 1.8 sxi whine from poss gearbox
    By psychosteve in forum Engine & Drivetrain
    Last Post: 2nd August 2010, 22:43
z20net squeal on acceleration
insignia 2.0 turbo f40
f40 gearbox whine
