Results 1 to 10 of 11
Thread: ecu issue signum 2.0t
    Sep 2012
    oxford
    Default ecu issue signum 2.0t
    hi all, i have just brought a 2004 signum 2.0t, when it get nice and warm it just cuts out and will not start again intill its cold down. had it tested and its coming up saying ecu fault, unplugged it, moved it so it was not sat on the inlet manfold and it ran for longer without cutting out.
    so what i am asking is can i get another z20net ecu and plug it in and off i go withut having to do any thing, or do you know a good, but cheap place to get it repaired
    many thanks
    robbie
    Sep 2012
    oxford
    Help please i want to know if i can just replace the ecu with another ecu from a signum 2.0 t of the same age
    Dec 2011
    Seaham
    Its possible there is a dry joint somewhere and when the engine gets hot, the joint breaks, re-making when it has cooled down.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    62 Post(s)
    Vehicle : insignia
    Trim : irmscher
    What is the fault code ?
    Irmscher Insignia CDTI 130
    Sep 2012
    oxford
    cant remember but every time it comes up with ecu fault, car runs fine intill the ecu heats up
    Sep 2012
    oxford
    Quote Originally Posted by Ben50n View Post
    how hard is this and whats need
    Dec 2011
    Seaham
    Need someone who can strip the unit and check for dry joints.
    Sep 2012
    oxford
    checked the ecu, and sorted the fault. but now the car has gone into limp mode ran a scan and no codes found. so i did the throttle padel and brake pedal check. which has flashed up these numbers
    10121
    10221
    106102
    once again any help would be great
    thanks robbie
    Dec 2011
    Seaham
    Check the codes on here
    http://www.obd-codes.com/trouble_codes/
    Sep 2012
    oxford
    thank you but cant find this one 106102
  1. Signum handbrake issue
    By Desolation91 in forum Suspension, Wheels & Brakes
    Last Post: 20th February 2013, 23:00
  2. signum starting issue 1.8 non vvt
    By Ashnak187 in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2012, 17:21
  3. Signum drivers window issue
    By Texx in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2012, 09:08
  4. Signum Travel Assistant Wiring issue (Newbie please be gentle with me!)
    By Daz Gleave in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2010, 15:50
