Thread: fitted carbon wrap on door trims not happy
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default fitted carbon wrap on door trims not happy
    the vertical pillars look ok but the bit round the mirror looks sh** ,looks like i'm stuck with it for nowas when i ceaned the trim before application i used solvent and it knackered the finish,went white and rough.i used a pre-cut set of ebay,in hindsight i should have bought a sheet of 3m and removed all the bits but it looks easy on utube,doh.just need to find out howto strip the mirror to get at the black bit and wrap it properly,i think the pillars front and rear come off easily.any help much appreciated.
    also wanting to do the boot strip with silver/grey carbon but looks like you need to buy a huge sheet to get the width but only need a couple of inches obviously to do the strip so quite an expensive mod unless someone has a strip of it i could have
    Trim : improving
    Year : 06
    any ideas?
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    57 Post(s)
    Vehicle : BTCC Edtion
    Trim : SRI LEATHER
    Engine : 2.0 TURBO
    Year : 07
    Dont think you can strip mirrors down. i just wrapped mine on the car. I put the film on the base and heated to fit and then trimed a round the colour coded mirror bit then used a second bit to do the under the mirror base etc. took ages to do but got there in the end!
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Pop glass an then the trim pops off or of your careful with a knife can just pop rear off
    2m sheet will more than cover the boot an mirrors
  1. Carbon Fibre effect Door pillars etc fitted
    By monty2000 in forum Styling
    Last Post: 12th October 2011, 14:25
  2. Carbon wrap a few bits this eve, well happy
    By MURDO in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2011, 23:40
  3. carbon door trims
    By cookiejar31 in forum Styling
    Last Post: 5th February 2009, 23:27
  4. carbon door trims
    By mhvcbv in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2007, 19:52
  5. diy carbon door trims
    By STAV in forum Styling
    Last Post: 16th February 2007, 22:04
