Results 1 to 10 of 19
Thread: loss of power 1.9 CDTi
    Regular Member ALD's Avatar
    South Lanarkshire
    Default loss of power 1.9 CDTi
    the car lost power this morning just after I had overtaken in 3rd.
    The spanner through the car sign appeared at that point, I assume its now in limp home mode.
    I will obviously need to get it in to the dealer as soon as poss, Im sure i've lost the turbo as I couldn't hear the usual whistle from it.
    anyway what I was wondering is can I use the car until it gets to the dealer, which wont be until early next week?
    Regular Member Ian's Avatar
    York
    I wouldnt unless its absolute necessity. Limp Home Mode is just that - to get the car home or to the garage. I wouldnt put it under a prolonged use until its fixed.
    Is the car staying in Limp Home mode after re-starting? If it is it deffo needs to go to a dealer rather than drive it for any length of time.
    Are there any other warning lights illuminated (i.e. emissions etc)??
    South Lanarkshire
    no other warning lights are on so far.
    i didn't have time to restart the engine, just stuck it in the car park and left it for now, I might have a go at lunch time around the car park to see if its back to normal.
    Sometimes, the car can throw a fit if booted hard and be fine after a re-start.
    Are you running it in standard form or with any modifications?
    South Lanarkshire
    just been out around the car park, the spanner disapeared when I started the engine this time, power seems to be back to normal
    when I stick the key in the ignition the spanner through the car symbol appears again but goes once the engine is started.
    so looks like its stored some kind of fault, think I would be safer still going to the dealer to see what the problem is
    AJA, i haven't made any mods to the engine, totally standard.
    You're spot on matey, it's telling you it has stored a fault in the ECU. If you speak to anyone who's owned a CDTi for any length of time, they'll tell you that these engines (1.3, 1.7, 1.9 & 3.0) all throw fits now and again if driven hard. In nearly all occasions it's nothing to worry about.
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    get it checked out alan just to make sure and if you need a lift anywwwere give me a shout you could even give autovaux a call and speak to my matey des and he will be able to advise you further
    South Lanarkshire
    well the cars booked in for next week at Reg Vardy.
    thanks for the offer pogo thankfully i'm off on paternity leave so not too much problem with travel next week
    I'll let you know how I get on
    Feb 2006
    Vehicle : Audi
    Trim : A5
    good luck with reg vardys mate, they arent the best and if they dont find anything wrong through tech 2 they will charge you, although to be fair the service manager matt is a reasdonable chap
  1. 150 CDTi power loss
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 15th December 2011, 12:48
  2. Loss Of Power On 3.0 cdti sri - please help
    By L.Hamilton in forum Engine & Drivetrain
    Last Post: 14th June 2011, 18:00
  3. Power Loss on 3.0 V6 CDTI
    By V6Andy in forum Engine & Drivetrain
    Last Post: 1st March 2010, 23:59
  4. 1.9 CDTI 150 loss of power
    By Nick_206_180 in forum Engine & Drivetrain
    Last Post: 22nd January 2009, 20:57
  5. loss of power 150 cdti
    By SRI-150 in forum Engine & Drivetrain
    Last Post: 17th May 2008, 14:24
