Results 1 to 3 of 3
Thread: Alternator/battery check..honda accord
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    confused Alternator/battery check..honda accord
    Hi..My mates just inherited his recently desceased fathers HONDA ACCORD,06 plate.
    Problem is that it has a history of loosing charge after about four days of standing. AA been out and say everythings fine BUT the problem still exists.
    Moneys tight,aint it allways, so I thought id ask for help here.
    It I were to check the batterys charge via a voltmeter when the cars not running with no draw,what kinda volts should i see?..and again with the engine running?
    I had to jump start his car last night as he n his kids had spent an hour or so cleaning it out and playing with all the various toys in it...ANY IDEAS?
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Once a battery is fully charged you should see at least 12.6v when the car is running you should see 13.5-14.4v if you switch on all the electrics (heater, lights, heated rear screen, ect) you should still be over 12.4v if not you may find the alternator is getting weak, also it's advisable to have the battery tested (not just with a volt meter) as you may find it has a weak cell.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Get a load test performed on the battery if you can
    but a good indication is check batt volt standing 12.7v is 100% 12.4v is 50%
    then check it while someone starts what does it drop too? Anything below 10.5 an battery is gogoose did if its only draining its got a parasitic drain some whwhere its probably far easier to watch a you tube video as they is more than likely a video on parasitic amp draw testing
    than me explaining.
    If not let me know an ill explain how to test
  1. Honda Accord 2.2 Cdti - any good?
    By GoldenWonder in forum General Motoring Chat
    Last Post: 24th June 2012, 12:59
  2. Honda Accord
    By VSRI in forum Non Vectra C/Signum Album
    Last Post: 3rd March 2012, 09:26
  3. Honda Accord EX
    Last Post: 31st December 2010, 17:57
  4. Honda Accord Diesel
    By VSRI in forum The 'Off Topic' room
    Last Post: 25th November 2010, 21:30
  5. 2.0t vs Honda Accord 2.4i (190ps)
    By paapaa in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2005, 07:17
