Thread: Twin fog switch. But...
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Twin fog switch. But...
    What will i need to be able to have front fogs installed?? I plan on making it driving lamp not fogs. The twin fog light switch unit arrive soon in the post, is it a straight swap?
    Will there be wiring ready to plug and play if i buy fog lamps? If wires needed, what wires? I found a few but for v. C up to pre-face.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I think the wires will be there they were there on my `120 cdti club.
    Have you ever had the front bumper off cos there cable tied to the bumper.
    Jul 2011
    UK
    Year : 06
    Tried this to my mates 55 facelift exclusive first I hot hold of a switch was a straight swap and all lit up great so I then removed the front bumper put the car on ramps 1st and bum no wiring to be seen anywhere so think am going to try relay some it to the switch
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    You also need the correct UEC module (engine bay fuse box).
    For some strange reason, Vauxhall chose to miss out an internal relay or module within the UEC.
    This module drives the Front fogs.
    I have tried at length to guide people through the fitment of the necessary wiring from the UEC to the bumper, but this is all wasted if you don't have a higher specification engine bay fuse box (UEC).
    Everything can be programmed in IPC - (instrument panel), BCM (Body control module) and UEC (Underhood electrical centre) and ligts up on the dash etc. but no front fogs.
    If you have check control enabled, it will show a fault as the circuit is incomplete - (again this is within the UEC).
    I have successfully used the relay method, using the ashtray illumination wire to trigger the relay.
    This is so that the fogs can only come on when the front side-lights are on.
    (The way it was meant to do in the old days).
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Quote Originally Posted by Mark-R View Post
    If they were cable tied to the bumper of of your 120 cdti club chances are someone has retro fitted the foglight loom, as the loom is attached to the inside of the front bumper via little clips on the inside of the lower bumper grills.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Yeah it was clips dont know what there called so cable tie came to mind LOL
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 Vtec
    Mileage : 64500
    haha
  1. Small 12v Auto circuit for on/off switch for PDC switch
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 23:00
  2. Replies: 25
    Last Post: 26th February 2011, 20:00
  3. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  4. vectra estate twin twin exit exhaust
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2008, 12:25
