Results 1 to 10 of 29
Thread: How would I
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Default How would I
    wire up my park pilot switch to work my after market parking sensors from eBay?
    These are the ones I've just fitted to my rear bumpers just yesterday and work a treat, well impressed with them so gonna fit them to the front bumpers now but wanting to use the PP switch I have.
    Sunny Dartmoor
    I think i remember reading that you can wire the live wire through the Park Pilot switch, there was a thread about a few years ago, do you how many connections are on the back of the switch?
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by glenboy View Post
    Mm 5 i think......so it would be just 1 wire to the live then, and 1 to earth?
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    You could get the ground in the engine bay then use a multi meter to bell the switch out meaning Wich actually creates the switch when pressed then wore a if option live to one side and live to ya sensors the other side
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by paulvectrac View Post
    Would something like work with it too Paul?
    http://www.ebay.co.uk/itm/Latching-r...item1c2ba37ffe
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    I carnt see why no matey but you wouldn't need that the way I said is the easiest and you only need some bell wire so to speak and a little no how
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    OK just the last wee bit of your first post is mixing me up Paul?
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Sorry mate lol if ya need any more detailed help let me no
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Yes please
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    No problem mate first things first get a multi meter put it on continuity then start on pin one press the switch see if you get continuity between any of the other pins if not go to the next an keep trying until you do so then once you have done that mate find an ignition live take it to the switch once you have done that extended the cable from the parking sensors only the live cable then the other cable at the Parkin sensor end is the ground connect the ground the cable you have just extended connect to the other side of the switch job done matey hope it makes sense
