Thread: about to fit new turbo advice needed
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    Default about to fit new turbo advice needed
    I am about to fit new turbo I have the how2 ect what I need to know is how to crank the engine a few times to get the oil pressure up without it actually starting then I dont damage the turbo
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    i think ian-highlander did his a few weeks ago ,have a search or pm him m8
    Jun 2012
    lancashire
    hmm about to go out the door to my borrowed garage its a 1.9 cdti sri if that helps
    Trim : improving
    Year : 06
    rom memory its v.v important not tospin turbo up without the oil being primed.could be expensive if you do it wrong m8
    Jan 2012
    Silverstone village
    Can you not just pull out the fuse for the engine electrics?
    Alternatively although more difficu;t remove the glow plugs , this will remove any compression.
    Trim : improving
    Year : 06
    its not the compression i think its running the turbo bearing dry that does the damage
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Just start the engine after you filled the oil. As the oil goes into the turbo hose as soon as the level is correct. Start engine and let it idle for 5 minutes then turn off and start again. Check underneath for any oil leaks as i did have a leak from one damaged washer connected to turbo oil feed. Very fragile!!
    Regular Member mat100edt's Avatar
    south coast
    Disconnect The coil packs leads, so engine can not fire, then crank engine a few times, you want all the belts and pumps to spin up but without sending gasses through the turbo (Maybe a bit late, but may help in the future)
  1. turbo squeal help needed
    By kirkyboy1981 in forum Engine & Drivetrain
    Last Post: 9th November 2012, 18:05
  2. Turbo Gone - Advice needed
    By Landers in forum Engine & Drivetrain
    Last Post: 22nd November 2010, 00:06
  3. Blown turbo advice needed !!
    By andymcniven in forum Engine & Drivetrain
    Last Post: 14th May 2009, 20:50
  4. Help needed fitting 2nd turbo
    By Inspektor in forum Comedy & Humour
    Last Post: 14th October 2005, 08:45
