Thread: 2.2 DTi inlet manifold,s
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Default 2.2 DTi inlet manifold,s
    A quick question to the 2.2 DTi owners , have any of you have a tp sensor on your manifold as well as the boost sensor .
    The reason i am asking is another member has asked about where to get a replacement tp sensor and to my knowledge 2.2 ,s do not have them fitted , just want to clarifiy the situation
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    i dont have 1 on mine
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    hi both our signum 2.2 dti have throttle position sensors infact i need to replace 1 of them.
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Yes, you have one.
    http://www.bosch.com.au/content/lang...cification.pdf
    Ours is part number Bosch 0 281 002 437 / GM 24459853 - 9158595 - 9196671 - 93171176
    Temperature output on pin 2 (see pinout page 37).
    Engine : 2.0DTi
    Mileage : 73350
    Just had a search on line for these manifold,s and came across this pdf .
    As can be seen the main difference seems to be whether or not the car is an auto or manual along with what they call low pressure and high pressure engine,s
    Opel and Vauxhall genuine OEM parts and accessories catalog
    Search for part number, part name or car
    We need your help! Our website can be closed soon Lear more...
    Home
    Vauxhall
    Vectra-c 2002-
    Fuel and exhaust
    Induction Manifold (Contd.)
    Vauxhall, Vectra-c 2002-, Fuel and exhaust, Induction Manifold (Contd.)
    Use large images.
    Links to this picture
    BB-code for web-boards and forums:
    For blogs and web-sites:
    <a target="_blank" href="http://opeloem.com/vauxhall/vectra_c_2002_/fuel_and_exhaust/induction_manifold_contd__9.html"><img src="http://opeloem.com/imgs/parts_groups/Z02/G/Z02_G_24_1.gif" /></a><br /><a target="_blank" href="http://opeloem.com/vauxhall/vectra_c_2002_/fuel_and_exhaust/induction_manifold_contd__9.html">Vauxhall, Vectra-c 2002-, Fuel and exhaust, Induction Manifold (Contd.)</a>
    Share you experience about this parts here
    # Title Part number Kat number Qty
    Induction Manifold (Contd.) Y20Dth, Y22Dtr Engines
    1 Manifold, Induction, Upper 24418320 8 49 144 1
    Description: (For Reduced Output Engine)
    Range:
    C
    C
    -21999999
    -28999999
    Description: (For High Output Engine) (Used With Manual Transmission)
    Range:
    C
    C
    -21999999
    -28999999
    1 Manifold, Induction, Upper 55350621 58 50 095 1
    Range:
    C 31000001-
    C 38000001-
    Range:
    C 31000001-
    C 38000001-
    2 Manifold, Induction, Upper 24459897 58 50 084 1
    Description: (For High Output Engine) (Used With Automatic Transmission)
    3 -Sensor, Vacuum, Inlet Manifold Pressure 93171176 62 38 210 1
    Range:
    C
    C
    -21999999
    -28999999
    Range:
    C 31000001-
    C 38000001-
    4 -Screw, Torx, M6 X 12, Vacuum Box Bracket To Induction Manifold 11093881 20 48 950 2
    Range:
    C 31000001-
    C 38000001-
    5 -Screw, Torx, M6 X 20, Induction Manifold, Upper 11095001 20 18 065 2
    Range:
    C
    C
    -21999999
    -28999999
    Range:
    C 31000001-
    C 38000001-
    6 -Screw, Special, Induction Manifold, Upper 11519824 (6 07 819) 2
    Description: (Nls.- Use 12992539)
    Range:
    C 31000001-
    C 38000001-
    7 Manifold, Induction, Upper 24460302 58 50 094 1
    8 Manifold, Induction, Centre 24461453 (58 50 085) 1
    Description: (Nls.- Use 55351994)
    Range:
    E -17D35838
    8 Manifold, Induction, Centre 55351994 58 50 100 1
    Range:
    E 17D35839-
    9 -Valve, Assy., Exhaust Gas Recirculation 9196675 (58 51 041) 1
    Description: (Nls.- Use 93176989)
    Range:
    E -17D35838
    10 -Screw, Torx, M6 X 20, Exhaust Gas Recirculation Valve To Inlet Manifold 11095001 20 18 065 2
    11 -'o'ring, Exhaust Gas Recirculation Valve 93172881 47 05 944 1
    12 Manifold, Induction, Lower 24418319 (8 49 142) 1
    Description: (Nls.- Use 55351529)
    12 Manifold, Induction, Lower 55351529 58 50 098 1
    13 -Box, Assy., Vacuum, Lower, Induction Manifold 9196674 8 50 087 1
    14 -Screw, Torx, M6 X 12, Vacuum Box Bracket To Induction Manifold 11093881 20 48 950 2
    15 Screw, Torx, M6 X 60, Induction Manifold Upper To Centre 11095271 20 24 201 4
    16 Screw, Torx, M6 X 60, Induction Manifold Centre To Lower 11095271 20 24 201 4
    17 Screw, Torx, M6 X 20, Induction Manifold Centre To Lower 11095001 20 18 065 6
    18 Gasket, Induction Manifold To Cylinder Head 90500940 8 49 193 1
    19 Gasket, Induction Manifold To Cylinder Head, Centre 9226543 8 49 521 1
    20 Gasket, Induction Manifold To Cylinder Head, Upper 9226544 8 50 678 1
    21 Stud, M8 X 37, Induction Manifold To Cylinder Head 9128191 58 50 863 7
    22 Nut, Hex., M8, Induction Manifold To Cylinder Head 90502418 8 49 928 7
    23 Bracket, Cover Fixing, Induction Manifold 24462329 58 49 993 1
    Range:
    C
    C
    -21999999
    -28999999
    24 Compound, Locking, 50 Grams, Manifold Stud Bolt 90542114 15 03 170 AR
    If you find our site helpful, please, like it
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    i thought these were electronic?
    im pretty sure mine hasnt got one.
    Engine : 2.0DTi
    Mileage : 73350
    Some vectra/signums do not have a tps on the throttle body , but have one on the actual throttle pedal itself . as per the top right manifold in the above pdf
    Regular Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    bobsignum: Thanks alot for sharing this one. Helped me to confirm what I needed. Now, after speaking with a Austrian dealer and my local Opel garage, there seems to be a difference wether it is a wagon or sedan/saloon also. So, there seems to be a need for knowing both engine size, gear, chassis, and model year. Different ECU gives different manifold. Not easy to figure out, unless you have the numbers stated on your original manifold: On my manifold I found matching numbers in your post, and thereby the kat number, and then I could order correct one from Germany. Price? €310 included shipping. Approx half price of my STealer.... Still, a heavy price for a sensor (only the TPS is not OK on mine).
  1. inlet manifold
    By spidermonkey in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2011, 22:07
  2. 1.9 150 Inlet Manifold..
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 18th July 2011, 20:29
  3. Inlet Manifold Done
    By Diesel Dude in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 12:32
  4. Inlet Manifold
    By topcat850 in forum Engine & Drivetrain
    Last Post: 13th November 2009, 14:33
  5. New Inlet manifold?
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 8th November 2009, 23:06
vectra 2.2 dti inlet manifold
2.2 dti engine vacuum box
vectra 2.2 inlet manifold
