Thread: Rear parking sensors
    Regular Member sthorpe71's Avatar
    Sep 2012
    Stockton on Tees
    Default Rear parking sensors
    Just ordered the sensor kit, where have you guys fitted them on your bumpers, I have an exclusive and was gonna drill on the very bottom/bumper spoiler but not sure if they will point slightly downwards?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Hi m8 if you take the bumper off you will see that the inside of the bumper is marked with 4 circles to denoting where the sensors are to go .
    linky
    http://www.vectra-c.com/forum/showth...nsor-positions
    and still loving it
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Take the bumper off and have a look for the marks on the inside where the factory-fit sensors go. Drill a pilot hole from inside out then from outside in with the circular drill bit. If sensors are tight fit, a dab of washing-up liquid on them makes pushing them in a lot easier. HTH.
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Hi mate, I got this kit in yesterday and fitted it already http://www.ebay.co.uk/itm/CISBO-Park...-/230384815553
    Take the bumper off and you'll see 4 marked position pre made by VX for their sensors, clean the dirt away from them and use the saw drill that come with the kit to make the holes for the sensors to sit in. Then run the wires for them from O/S to N/S then through the hole just under the bodywork on the N/S you'll find a rubber grommet and just burst a hole in it then run the wires through it into the car and it'll come in just at the rear fuse box. The sensors will have a stamp on them saying UP, this tells you that this must be at the top when fitting them. Wire it up, RED cable from power goes to the reversing light wire RED/BLACK is grounded to the body work, plug in sensor wires and display or buzzer put car in reverse and job done
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Now looking at putting them on my front bumper but just need to figure out how to wire them for the front.
    Sep 2012
    Stockton on Tees
    Cheers fella's, its the same kit black knight so very helpfull ta. Is the bumper easy to remove?
    Feb 2011
    Trim : Sri
    Engine : 2.2 Direct
    Yes. I can't remember exactly how - check out the 'How 2' forum, I'm sure you'll find something in there. Easier than removing the front bumper!
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by sthorpe71 View Post
    Remove both back lights, unscrew 2/3 screws from back wheel arches, remove number plate and plate lights too, unscrew 2 screws either side of these light at number plate, then remove 2 clips underneath the bumper then gently pull bumper away from bodywork BUT minding when you reach the bend in the bumper be extra careful because if you pull too quickly it can/could tear it.
    Here is the link to removal too
    http://www.vectra-c.com/forum/showthread.php?t=21565
    Sep 2012
    Stockton on Tees
    Once again, thank you, a great help
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Your're welcome mate.
  1. Rear parking sensors
    By blackviper90210 in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2012, 21:49
  2. Rear Parking sensors.
    By Maverick in forum Parts for sale
    Last Post: 24th February 2010, 23:58
  3. Rear Parking Sensors
    Last Post: 22nd April 2009, 23:44
  4. Rear parking sensors
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2009, 22:44
